SOURCE: Locating the filter on the Hotpoint WMA54 front load washer
To check and clean the filter, you need to remove the lower rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for obstruction or blockage here and in the pump as well.
Hope this helps to solve your question.
Please leave feedback.
Thanks.
Testimonial: "Spot-on advice ticked all the boxes. Problem appears to have been resolved!"
SOURCE: LG front load washer OE error. cleaned filter need
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!
SOURCE: Brada TM Modele BBF21KASB/XAC
Here is a tip that will help you to get better results from your question on Fixya.
How to ask a question on FixYa
heatman101
SOURCE: There is a strong odor
run a empty load, and add a cup of white vinegar , that should flush out any bad odor thats in the machine itself
heatman101
