SOURCE: whirlpool double oven. fan assisted oven is not heating up fan is
NEEDS A NEW HEATING ELEMENT
SOURCE: F2 E6 Codes appear, time flashes off and on
HI, this is a faulty key pad issue. check the following.
1. Check keypad connector for firm connection (keypad connects to control
board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad
(also called touch pad or membrane switch). Some models incorporate keypad
in to control board as one unit. In this case, replace control board (also
called ERC or clock).
SOURCE: I have a Whirlpool RBD275PDS14 double oven. It
Look for a blown fuse mounted on back of the controltis page is in the MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Whirlpool Double oven control panel
A lot of people seem to have ran into this problem. I had no luck finding a solution to this problem anywhere on the internet. I finally fixed this problem by replacing the control board. Wanted to put this info out here for others. The part swaps out fairly easy for all of you considering the fix yourself. Sears direct had the cheapest price.
