The canon printer error code 5800 means the waste ink counter reset. Your canon printer need to reset after performing a lot of activities.
Steps to fix canon printer error code 5800
Replace the waste ink Absorber using the following steps:
1. Press the stop/reset button when your canon printer is on. Also pressing and holding the power button.
2. After performing above steps, now your printer is in service mode
3. Check the power light is green, press the stop/reset button twice
4. Make sure to press the button 4 times to reset waste ink counter.
Solution 1: Replace the Waste Ink Absorber
Step 1: Press the Power Button
* With the Canon Printer Powered off but connected to a power source. Press the "Power" button while pressing and holding the "stop/reset" button.
Step 2: Press the Stop/Reset Button
*When the Power is lit, press the "Stop/Reset" button two times
*While pressing and holding the "Power" button
Step 3: Move Into a Service Mode
*When releasing the "Power" button and the "Stop/Reset" button (regardless of order), the printer will move into a service mode. (waiting for menu selection)
Step 4: Press "Stop/Reset" Button
*When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.
(Each time the "stop/reset" button is pressed, the LED lights alternately in orange and green, starting with orange)
Note: Make sure there is need to press 4 times for waste ink counter reset
The number of the Reset button pressing LED Function Remarks
*0 time Green Power off
*1 time Orange Service pattern print
*2 times Green EEPROM print
*3 times Orange EEPROM reset
*4 times Green Waste Ink counter reset
Step 5: Turn on Canon Printer
Turn off the printer, then turn it on again.
Now Check the Canon printer error code 5800 is resolved. If not, then go to the next solution.
Solution 2: Enter Canon Printer in Service Mode, works best for multifunctional printers.
Step 1: Turn Off Canon Printer
Step 2: Go to Press the Menu Option
Step 3: Put Printer in Service Mode
*To do this you will have to press the "SCAN", "COPY" and "SCAN" buttons in that exact order.
Step 4: Reach to the "Counter Access" option
Step 5: Check amount of pages that you are printed
Press the "ok" key
Step 6: Press the "COPY" Button
Step 7: Score all the way to zero
Step 8: Stop once get "Scan Page Count" Option
Step 9: Set Score back to zero
Step 10: Press the "STOP/Reset" button
Step 11: Turn Off "Stop/Reset" button
Step 12: Disconnect the Power Cables and reconnect
SOURCE: Canon PIXMA MP140 error code E 2
error E 2 =>
The machine is out of paper. / Paper does not feed.
Reload paper in the Auto Sheet Feeder and press the Black or Color button.
SOURCE: ERROR 5800
1. Turn off printer.2. retaining button Stop/Reset (red triangle in the circle) press button POWER - indicator it will light up with green color.
3. let go button Stop/Reset, continuing to hold POWER.
4. press button Stop/Reset 2 times, while holding POWER button, after which you will let go all buttons.
5. when indicator is lit BY Solid GREEN - press Stop/Reset 4 times! (this is the key)
6.turn off printer by POWER button, then turn on.
7. You should be set. If it didn't work, try it again, slowly. It WILL work!
SOURCE: canon printer pixma mp110
My Pixma MP110 keep on displaying "CHECK PRINTER (5800)" Please have m to solve this problem
SOURCE: Error code 5800 for Pixma MP130. When try to get
you can try this:
Turn on the printer (MP130) and do the following:
1. Press MENU SCAN COPY SCAN to enter service mode
2. Use > to go to NVRAM ACCESS
3. Set ABS-M LEVEL to 0
4. Set ABS-P LEVEL to 0
5. Press STOP to exit
Done, hope it work.
SOURCE: Canon MX 308
How to reset canon MX 308 ??
Error Code 5800
Any Software to reseter this printer?
