SOURCE: The door lock flashes constantly - Indesit WIA101
Switch on machine and start its program. While it is running then turn program selector control to TOP position. After a few seconds ALL lights should flash and machine should stop. It ought now to have been reset to normal.
SOURCE: Whirlpool AWM8121 ?door open? light flashing
I had the same problem about a year ago, I replaced the door switch but didn't fix it, I found the brushes in the motor has worn out - Replaced the brushes and fixed the problem.
SOURCE: Hotpoint Aquarius WF440 Washing m/c - Door Lock light
You have probably knocked of the connector or the catch (and on these it is very fragile as I have changed the catch 3 times on mine) is broken
SOURCE: door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
SOURCE: Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Hi
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged
drain hose or the water pump. You’ll need to drain the water out of the
base and also check to see if there's something
stuck inside the pump or the drain hose connected to the pump (pump is usually
located at the bottom and towards the back of the washing machine). If the
drain line isn't clogged, you may have a problem with the water pump such as a
frozen pulley or a broken impeller. If that's the case replace the water pump. Please
do accept the solution if the issue is resolved or else revert for further
assistance.
Thanks
Rylee
