Health & Beauty Logo
Ma go be John Posted on Jan 31, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Weighting scale showing EI0.11 - Health & Beauty
jws1013
Level 3:
  • Health & Beauty Master 1,713 Answers
  • Posted on Feb 02, 2020
jws1013
Level 3:
Answers
1713
Questions
Helped
458603
Points
6786
Remove the batteries for a few minutes then reinstall them making sure they are in correctly. If the error persists, contact the manufacturer for support.
1helpful
HOW DO YOU ADD UP TH FINAL MARKS?
It depends on your jurisdiction. In Ontario, the term mark has a weighting of 70, while the summative and final exams have a combined weighting of 30.
To illustrate, let's do an example.
Term mark worth 70% of final grade - 70
Summative mark worth 10% of final grade - 80
Formal exam mark worth 20% of final grade - 90
Your overall final mark would be as follows
70 x 0.70 = 49
80 x 0.10 = 8
90 x 0.20 = 18
Overall Mark 75
Good luck,
Paul
1helpful
2answers
How do I calibrate the Welby Health Body Fat scale? The scale in the picture is NOT the scale in question.
Scales are supposed to show correct weigt. Who told you to "calibrate" it? Your scale is not working correctly. Return it and ask for a good scale
How do calibrate my scale. it is a asking for 500.0 grams of weight to do this. can i use coins? if so what
two cups of water are about 500g, 500ml of water is 500g, just measure 500ml of water, put it in no leaking plastic bag and use as a solution to your scales calibration problem, as i am assuming you will not use it to weighting 500g of d0pe or m eth, error of 2 or 3 grams will be of no importance!
regarding fixya - stupidity of censorship is astounding! d0pe and m eth in correct spelling are regarded as profanities...
Jan 02, 2015 • Home
I have replaced the batteries in my Glass WW scales and within a week it has needed some more. I have now done this twice. Buying the batteries at different shops, just in case it was them. Now I am...
this is the problem with moisture. and the circut is broken. i think the repair is costliar then new one
1 suggesion is daily remove the battery after weighting. and put it back when you needed
4helpful
My bathroom scales ww35cha stopped working, i replaced the battery and now the scales turn on, but do not display a weight when u step on. Instead the weight shows '0'
you have 4 button on this model
1 tap the scale to start, it show 0.0
2 tap set to set person and height, age ...( use set, up, down buttons )
done
when start use
1 tap scale to start , show 0.0 again
2 tap user again and again to choose your user
3 wait after it show your height, age, then it show 0.0 step on the scale and you're done.
i've been through becuase my friend lost his instruction manual.
Now it wook
Have Fun
[email protected]
I have a Digistar EZ2000 has error saying indicator need service
Depending on which error is coming up, you should probably get it in to a Digi-star service center. If it is error 2 or error 5 it will need to have the Eprom replaced. The total cost of the repair at Sioux Automation Center in Sioux Center, Iowa would be about 45$ depending on where it needs to be shipped back to. they can also send you a loaner so that you don't have any downtime. You can call them at 866-722-1488 and they will be able to explain it to you in a little more depth.
4helpful
2answers
I have a chefmate nutritional scale that was working fine,then all of a sudden the screen started saying out2. replaced batteries but nothing so far.
It is not OUT2, but rather OUE2, which means your chefmate needs to re calibrate. To do that you will need the following:
a 2000 grams weight or 4.4 lbs, I used a 3lbs protein jug unopenened and a 600 grams glutamine bottle unopened.
Ok so turn your scale off then:
1) press the ON button and leave it press while simultaneously pressing once the TARE button (though it may need more than one or maybe leaving it press for a few secs thought try just hitting it once first), release the TARE and you should see a CAL on the screen (top left), release the ON and it will read:
2) the number 00000 on the first line will appear, click TARE
-this calibrates no weight first-
3) then it will read you another weight mine read 2000 grams, put that weight on top of the scale (NOTE every scale uses a different weight to calibrate i am giving you mine) once you put it there hit tare and it should read PASS
4) Remove the weight and it should read "0", mine read first 1 grm so i had to re do it again until i got 0.
5) You can try weighting different unopened things that you know the weight of, but if not just turn it OFF then back ON and it should read "0"
Congratulations your scale is now calibrated and ready to use again!!!!
NOTES: i have the electric scale if the on tare button does not works for you it may need a different combination to calibrate.
Top Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Health and Beauty Expert? Answer questions, earn points and help others
