Https://www.daisy.com/wp-content/uploads/2019/06/426.pdf
Make sure that the magazine is not empty or over filled
SOURCE: leakin air cylinder on my daisey model 3880 bb gun rifle
The o-ring or gasket is worn and can't take more pressure after the 5th or 6th pump, you should be able to get a gasket kit for it from your retailer. Hope that helps!
SOURCE: very hard to pump
It needs lubricating. Take it apart, clean it, then put machine oil on the moving parts and seals. If seals are damaged they need replacing. And, please only use it for target shooting.
SOURCE: Daisy Red Ryder BB gun won't shoot
1) **** the gun and look through the hole in the top, half way down the barrel.
2) You should see a BB loaded into this area.
- if no bb is present and you can see a circular magnet, then it is not loading.
3) if the bb is present and does not exit the barrel when you fire the gun, then the bb is deformed and will require the rifle to be dissasembled and rodded through the back side, forcing the bad bb out of the way.
4) If no bb or magnet is present through the hole, call daisy for a replacement. This indicates the shot tube has moved and will no longer load.
SOURCE: Looking for manual for an old Daisy Air Rifle.
what you thought was the serial number is actual the state and zipcode for daisy air rifles in rogers arizona, 72756 but try this page here and see if it can help you
http://www.daisy.com/_manuals/spring_air_english.pdf
SOURCE: Daisy Eagle BB Rifle not
Click on this link below to learn how to fix a Daisy BB gun
http://www.ehow.com/how_5844747_fix-daisy-bb-guns.html
Click on this link below and fill in the form to order replacement parts for your Daisy Eagle BB Rifle
http://daisy.com/serviceform.html
