All good fixed I plugged in power ,held my finger down on the power button on the machine and it started Cheers
Knocking out the power to the power box suggests the RCD or ELCB tripped, rather an MCB?
When the RCD or ELCB trips it is because some current is leaking to ground - either because of a fault in the wiring, power cord or most likely the appliance.
Lots of such faults are intermittent for a time before becoming permanent. Steam irons are particularly prone and washing machines; usually caused by a small water leak...
SOURCE: Fuse blown
sounds like the smpsu (power supply)is faulty.
if the fuse is black inside it means there is a s/c
on the psu if the fuse is clean it generally means
a faulty component on the board.
Either way replace or repair psu.
mongrelken.
SOURCE: LG 1412RD Tips main fuse.
You have a dead short either in your breaker box or the plug in. Chances are it is your receptacle.
SOURCE: Cigarette lighter doesn't work
try a google search for online fuse box diagram for your car
list make and exact model like accord ls, dx, ex, whatever it is. I tried to scan/paste a diagram here but it would not be undestandable as it jumbled it up.
SOURCE: LG LFC23760SW stopped working-no power. Power
Unplug the unit and remove the board cover. The fuses are soldered in but can be changed with a soldering iron. They are glass and easily spotted on the board.
SOURCE: there are 2 lighter plugs
{: ) There are two fuses that protect the front IP power outlet or lighter plugs. At the underhood fuse block, labeled CIG LTR 15amps and AUX PWR 20amps. See red arrows on diagram below.
The fuse on the driver side door fuse block labeled AUX PWR2 20amps protects the rear lighter plugs.
Testimonial: "Just noticed that I could respond to this. I found this shortly after you posted it and found the under the hood fuse box and the blown fuse. Thank you. Was then able to get the code for the check engine light. That problem was never fixed but stopped happening when the weather got cooler."
