Dryers Logo
Alicia Gilmer Posted on Feb 02, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a dpsb613edww dryer when i plug it in all it does is click and blink i trying to get some tips on fixing it
CJ Rock
Level 3:
  • Dryers Master 4,429 Answers
  • Posted on Feb 03, 2020
CJ Rock
Dryers Master
Level 3:
Answers
4429
Questions
0
Helped
1644928
Points
15024
Https://www.repairclinic.com/ProductDetail/611659?tab=problems
HOW DO I FIX MY DRYER WHEN IT RUNS BUT DOESN'T HEAT?
I've created a no heat clothes drying tip to help you troubleshoot your issue. Click on my name and then click on my tips, and pick the appropriate tip title.
What lengths do I stretch the heating element to for my ge dryer dpsb613edww?
You plug it in on one end and run it through the guides to the other end and hook it up there.
Jul 19, 2014 • GE Dryers
I have electric dryer, it tumbles but no heat. Someone told me heating element. I read where you have to take out drum from front to get to it. Is it worth replacing or buying new dryer/
If you can disassemble the dryer, you should find full troubleshooting instructions including the resistance of the electric element and which terminals to test. If the resistance is out of specifications, maybe you could replace it. Parts are generally available at appliance parts stores.
Gary
GEW92509W0 will not start. When you hold start button, it beeps like door is open. Tried many settings. It will only blink "sensing light" . No error code is blinking in the display. Plugged...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
The drum of my dryer will not turn
Hello my name is Heath it will be my pleasure to assist you. The belt for the drum may have come off or broke you will have to pull the top to veify that the belt is still on and the motor spins when the dryer is turned on.
Dryer runs but doesnt dry clothes
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
My dryer squeaks when running a load. How do I fix it?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Where is the heating element located on the GE DPSB613EDWW / DPSB613EDCC Electric Dryer ?
the heating Element is located behind the drum...In order to acces you would need to remove the complete drum from the front of dryer..
Dryer won't get hot
Probably a heating element. I have a pictorial that shows how to get into the machine. Click HERE.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 06, 2009 • Dryers
Top Dryers Experts
john h
