SOURCE: ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
SOURCE: Low battery
You need to buy new batteries for your phones. Large retailers charge $10-12 per battery but you can usually find them for closer to $4 online at amazon.com or eBay.
SOURCE: change battery
If it is cordless, it has batteries. You can usually tell if the small red light is off on the bottom.
Most mice have the battrey compartment in the rear half of the top of the mouse. The rear half slides off. Something like this:
Yours will probably hold 2 AA batteries. If it is one of the smaller ones it may have the battery compartment underneath and take 2 AAA batteries.
Hope this helps.
Thanks for using Fixya.
SOURCE: Delta cordless power tool batteries CL 180B
My batteries also would not charge and I thought it was the charger. I then used some fine sandpaper and cleaned up the connectors on the batteries and I now have one charging. I will try the other one as soon as the first one is done. It looks like the charger doesn't contact the battery in the same places as the tools and they get dirty. I love my set and don't want to loose them. I just don't use them enough to need charging often.
