Washing Machines Logo
R
Raymond Klein Posted on Feb 03, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore elite oasis F1 error when I start If I gently lift the lid a fraction after a few attempts it runs normally until 16 minutes left. Then I have to repeat the sequence to complete the wash cycle
Jorgie Navito
Level 3:
Master:
  • Kenmore Master 357 Answers
  • Posted on Mar 16, 2020
Jorgie Navito
Kenmore Master
Level 3:
Master:
Answers
357
Questions
0
Helped
108955
Points
2245
A safety feature found on front load washing machine is thedoor switchand the door lock and strike. On most models, the door switch must be closed and the door lock must be activated before the washer will start. The switch is normally located in the door frame of the washing machine, but may also be part of the door lock assembly. Inspect the strike to make sure that it engages the door lock assembly and that the door remains closed. To check the door switch for continuity with a multi-meter, you will need to disconnect the power and remove the front panel.
The lid switchon a top load washing machine is a safety device designed to prevent the motor circuit from operating when thelOnsome models, the water inlet valve circuit is controlled as well. If the lid switch fails, the washer may not start. The lid switch is normally located beneath the main top with a projection on the lid or a pin attached to the lid that will actuate the switch when the lid is closed. Verify that the switch is being activated mechanically and that any levers or actuators are not damaged or sticking. If the switch is being activated but there is no power being supplied to the motor or water valve circuits, then the switch may be defective
The start switchon some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in
God is good and that's why I give free advice.
Kenmore elite oasis F1 error when I start If I gen - doorswitch bypass-lid-switch-unplug-undefined-undefined-0.jpg
5 Related Answers
Anonymous
  • 91 Answers
  • Posted on Jan 04, 2009
SOURCE: kenmore elite oasis f-1 error code about every 4th washing
main control board need replacing
Anonymous
  • Posted on Apr 29, 2009
SOURCE: Kenmore Elite Oasis HE getting F1 code. What does this indicate?
your board is confused and cannot read water level, very easy fix, pull off console(three screws on rear) and remove clear hose on right side of main control. blow into with your mouth and clear tube. reconnect hose and try, if F1 continues main control will need to be replaced, Sears is offering this for free if your unit falls within a certain serial number range, Also a biggie.....You must use he soap only with the oasis....no exceptions.....
Anonymous
  • 530 Answers
  • Posted on May 29, 2009
SOURCE: F1 error code on Kenmore Oasis He
I think there might be a recall on your washer call to see. I am not for sure that there is a recall but I a m pretty sure there is. So don't quote me on that. the f1 error code usually means that you have a bad board. f1 means that your pressure switch line is failing and this is all in your board. check your owners manual if whirlpool is not going to pay for this repair sometimes there are extended warranties in your manual
Bruce Robin
  • 300 Answers
  • Posted on Apr 09, 2010
After getting the F1 error on my model 110.27086601 and looking at other posts here & elsewhere, I made one call to the "Product Resolution Center" at 800-847-9083 on 4/9/10. They answered quickly, looked up the model & serial number I gave them (begins with CT18) and confirmed that the unit is covered under the "upgrade plan" (as opposed to calling it a recall). They are sending the part directly to me today and they scheduled a Sears tech to come install it in 10 days (or less if the part arrives sooner). The part, shipping and service call are free. The whole call took less than 5 minutes and was no more difficult than ordering a pizza. The agent was polite, professional and a pleasure to deal with.
I'm pleased that 2 years after the warranty expired they are providing this repair free of charge and without any hassle.
To those who have had problems when calling or who will be calling, may I offer this tidbit for dealing with any customer service contact? Be polite and businesslike. The agent on the other end doesn't need to hear about "how disappointed you are, blah, blah" or that you've "been a loyal customer for 84 years" and you've "never had a problem like this" or any other editorial commentary - just be friendly, and say something like " Hi, I have an Oasis washer with the F1 problem and I understand that there's a recall covering this." That's exactly what I said and the agent efficiently handled everything from there.
Remember, the agent gets measured on the number of calls they complete so they just want to take care of you as quickly as possible. Help them by just simply stating the problem and just answering their questions with just the information requested. They are not there to listen to people whine - they've heard everything you have to say a thousand times and they will appreciate your brevity and no nonsense demeanor. Make it easy for them and they'll make it easy for you. Do your venting here if you must.
Anonymous
  • 33 Answers
  • Posted on Apr 28, 2010
SOURCE: Kenmore Elite Oasis HE top load washing machine F1 code
Ok so you will all love this answer. Not only do I own this set but I also sell them at sears in des moines, ia. Ok so there was a recall on the controll boards it's fine don't be scared all you have to do is call 1800-659-7026 give them your info and model and ser.# they will then send someone out to replace the control board it takes about ten min for all of it and it is all free no matter when you bought it. But in mean time quick fix for all of you is to unplug the washer then hit power then stop over and over tell there is no power left in it then plug it back in and it will work fine for awhile you may have to repeat if it does it again. But after they come out it will work fine. yes this has happened to me it sucks it took two years to find out what was wrong they didn't even tell us I had to ask alot of parts guys and look it all up. So for everyone that this is happening to I'm sorry I just hope this gets out to all of you because I work very hard to know my product and take care of my customers ask any of them and it's not easy working STRAIGHT commission and people don't want to come back for these kind of things. But remember the reason why you came there in the first place we will give you the lowest prices in town and we know what we are talking about, well most do if not they ask me:) so I realy hope this helps someone out there.
What does a flashing F51 code mean?
Dump the appliance. sears delivers the worst garbage available
What is F1 failure code on a kenmoore oasis washer
check your owner manual section troubleshooting for error code very important.
Normally this error code can be meansL a) pressure out of range.
or b)eepron error.
or call the factory and get support online via chat or phone for to fix it.
God bless you
1helpful
I have a Kenmore Elite top washer and was wondering how to lift the top to clean
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
1helpful
F1 error
yep electronis control board in the console is bad.
10helpful
2answers
F1 & F51 error on my Kenmore Elite Oasis HE washer
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the bad board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Side vent
5
6
7
Need to disassemble a kenmore elite oasis dryer
5
6
7
9helpful
2answers
Kenmore Elite Oasis HE/ Error Code F1
repl/ main control board reason for error code F 1 ,,,nothing else
1helpful
Ok these are not the series 70, getting a model number off the door will reallllllly help. Some of these sound like the oasis. F1 is motor control or primary control failure and F 41 is a rps thermistor failure.
For the guest with the 11027086601 kenmore elite oasis here is a link for supplying me with a partial model number, much thank yous!! paste in a browser:)
http://www.searspartsdirect.com/partsdirect/retrieveSubComponentPartsAction.action?modelNumber=11027086601&productCategoryId=0153200&brandId=0583&modelName=RESIDENTIAL WASHER&diagramPageId=00002&componentDescription=CONTROL PANEL PARTS&documentId=K0601003&backToLink=Return to Sub Components list
Alexander
vince
