SOURCE: Dryer wont stay running
Either the motor relay, or if this is an evenheat dryer, the evenheat control board could be bad.
SOURCE: press start button but wont stay on
the switch is fine
the switch in all dryers triggers a relay, that then latches and supplies current to motor and heater, until deactivated by door switch or timer switch
inside the control panel,
trace the wires from the start switch to the first device
may be opaque.
ensure that the wires are all connected.
if all are connected replace relay
the local part store will have the relay it is common to most dryers
Cant give exact instructions, no experience with particular model
SOURCE: have new switch for belle 110v cement mixer
This should be pretty easy. you should have either two or four wires in the box and two or four hook ups on the switch. the wires in the box must stay aligned with the matching colors so if your switch has four connections but you only have two wires hook them up to the post opposite each other top to bottom. (they need to both be on the same side) if you have four wires but only two switch posts wire nut the two white (or blue) together and switch the black (or brown). The important thing to remember is the power needs to come in on go into the switch or breaker first.
let me know if this wasn't helpful
SOURCE: electrolux dishwasher all lights blinking and wont
Remove the toe kick by loosening 2 screws. There is a panel there with little lights that correspond to specific problems. The light that is on will correspond to the problem that the dishwasher has detected. Correct the problem and you should be good to go. I have no idea why this is not in the instruction manual. A common one is that there us a leak that the dishwasher has detected, normally in the drain pipe.
