If your Vizio TV has sound but no picture, and you have already done the flashlight test, it may indicate that your TV's backlight or power supply is malfunctioning. Here are some steps you can follow to troubleshoot the issue:
Check the cables: Make sure that all cables are properly connected between the TV and any devices you are using, such as a cable box or DVD player.
Check the input source: Ensure that the TV is set to the correct input source that the device is connected to. You can cycle through the input sources using the input button on your TV remote.
Power cycle the TV: Turn off your TV and unplug it from the power outlet for at least 1 minute, then plug it back in and turn it on again. This can sometimes resolve issues related to the TV's power supply.
Reset the TV: Try resetting the TV to its default settings. You can find this option in the TV's menu settings.
Contact support: If none of the above steps resolve the issue, it may indicate a hardware problem with the TV's backlight or power supply. In this case, you should contact Vizio support or a qualified technician for further assistance.
If you can see an image on screen via flashlight test then the backlighting is not working. And the inverter board is the unit that powers those lights ..... So....................
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the Screen ... Was working fine and now blank ...
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
My tv stopped working, it had the sound but no picture, so I did a little research and fixed it. ... vizio E701i-A3E ...
? 5:06
https://www.youtube.com/watch?v=fSCf1xxLjNA
Aug 27, 2015 - Uploaded by ShopJimmy.com
Basic Troubleshooting Help if your Vizio LED TV has a blank screen and no ... It is on an UPS but turned off ...
It sounds that the T'Con board has failed. If you are not familiar with
electronics, do not attempt to repair.
Whether you suffer fatal electric
shock. Instead, contact
any experienced service technician, or the nearest service center.
Hello. If sound turns off for a couple of seconds it is actually not an issue but normal operation. When you switching between formats different software protocol is in use and it need some time to synchronize.
In case if sounds turns off and stays off you have to make sure where this problem is originated. If you have DVD player with both standard and high-definition outputs - connect them both to the different TV inputs and switch to see if problem is still there. If sound comes back while using DVD - you might have problem with your cable/satellite box and TV has nothing to do with it. If DVD "test run" creates same issue - main board in your TV have to be replaced. Vizio have many software/firmware - related issues. Regards. Russ.
any luck? might 37" vizio just had this problem, all of a sudden no picture sound just fine, I call vizio and they say could be motherboard, do I bother fixing this, or just get a new one?
