Video Game Consoles & Games Logo
Cait Johansen Posted on Feb 05, 2020
I had just finished watching a movie on my ps3 slim and it had just started to go back to the home screen (still dark and the dots of light were barely visible) when I accidentally ejected the disc and the system froze. I powered it off by holding the power button, restarted it, let it do the usual system check it does when it doesn't power down properly. It got to the home screen, I put a new DVD in, hit play and it froze while trying to load the movie. I powered the system off again, the same way. I tried to turn it back on but the screen stayed black for at least 10 mins. I restarted it in Safe Mode and tried to restore default settings (figured it'd be the easiest and wouldn't affect my game files). The system tried to restore for 3 days, so i figured it was frozen again because the HDD light wasn't on. Restarted in Safe Mode again and tried all of the options; restore file system and rebuild database don't work, my system stays on that screen and the HDD light isn't on, system update causes the system to freeze right there, and when I finally selected restore PS3 System, it says that the system storage cannot be accessed. What on Earth happened to my PS3 and is it possible to fix it without buying a new HDD?
Lee H
Level 1:
Habit-Forming:
  • Contributor 23 Answers
  • Posted on Apr 08, 2020
Lee H
Contributor
Level 1:
Habit-Forming:
Answers
23
Questions
0
Helped
11012
Points
64
Hi.
Looks like reset to me.
Follow the instructions bellow.
How to factory reset SONY PlayStation 3 Slim.
The following tutorial shows all method of master reset SONY PlayStation 3 Slim. Check out how to accomplish hard reset by hardware keys and settings. As a result your SONY PlayStation 3 Slim will be as new and your core will run faster.
1: Begin by switching off your PlayStation 3 by holding down the Power key for about ten seconds.
2: You have to wait until your device is completely switched off and the power indicator is flashing solid red.
3: After that, press and hold the Power key again for about seven seconds, you should hear two short beeps.
4: Connect a DualShock 3 controller with a USB cable.
5: Press the PS button on the controller.
6: From the menu, scroll down to the Restore PS3 System option and confirm your choice by selecting "Yes".
7: Your console will now perform a factory reset process.
Hope this works, good luck.
3 Related Answers
Anonymous
  • 15 Answers
  • Posted on Nov 03, 2008
SOURCE: No main menu, just wavy lines with sony entertainment
This is a hard reset of the system, used when there is a catastrophic error etc. I have trawled these kind of sights and the main concensus is to ensure you have a back up of all important data. I experienced the same issue but the method above was advised by my games shop.
whitewolf4x4
  • 27 Answers
  • Posted on May 02, 2010
SOURCE: PS3 SLIM FREEZING
The problem is update 3.30. Whatever it contained, it hurt the systems ability to read from the BD Drive. I suspect you can play downloaded content forever without freezing. If correct, the is currently no fix. I am in the same boat. Our only hope is that Sony will come forward with a fix. Currently, if you call them they will say your system is faulty and you need to send it back to them for a swap.
Anonymous
  • 366 Answers
  • Posted on Feb 04, 2011
SOURCE: i was watching a dvd
Whenever you have a system that shuts down like that, you can expect to have hard drive problems.
ry accessing the recovery menu 'safe mode'.
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until you here 3 beeps. Let go.
If you have a HDMI cable, plug it up, if you have AV plug it in as well. If you have both settings on your TV, be sure to have them both inserted into the system. Also, make sure that you are switching your TV from HDMI to AV and vice versa.
It should ask you to connect your controller via usb and press the PS button in
the middle of your controller. There will be a menu with 6 options. Try 1-5
If none of this works:
ou will need to replace the HD.
When you replace your hard drive, you will need to have the latest firmware on a
usb stick. Download the firmware from the playstation official website onto a usb
stick. Once prompted by your system you will need to insert the usb stick into the
PS3. Good luck..
You will need 2.5" Sata Hard Drive.
3answers
I need to renew my ps3 BD encryption key to watch blue ray movie
Some newer blu ray discs require that your system be updated to view the movie. This is due to a security "encryption" set by various movie companies. (they are trying to prevent people from copying their movies).
If your PS3 is connected to the internet this should be done automatically when trying to view the movie.
hope it helps
~good luck!
Red screen of death
The arrival of PS3Slim 120 GB has completely changed the gaming scene. Not only can you play games with a PS3 but also do other things including, watching movies and even use as a PC. One of the good things about how to fix PS3 slim 120 gig is that if any problem occurs in them, you can easily fix ps3 ylod, provided you have some basic troubleshooting knowledge.
Red screen of death what to do
1helpful
2answers
Ps3 not reading discs!
If you keep on getting this problem you will need to send it in to get it fixed, or you can actually readjust the laser from home.
To do this you can use a good repair guide.
Not playing Movies
Do a ''Quick reformat'' a full one may take over 2hrs - happend to me this week - it worked
TV Screen is to dark when playing games or watching movies
turn off enegery saving mode cheak coler britness lock it into your fav user settings on all inputs eash input hdmi has it own coler u must adjust ok to fit needs on eash input k
I just finished watching a movie on my ps3 and now it wont read any discs
First try putting the movie you watched when this happened, back into the PS3, see if you are able to watch this movie and if it reads this particular disk... if it will, contact the company and tell them that your PS3 isn't reading any of the disks, they will send you a box and repair your PS3 free of charge and send it back to you in about 3 weeks.
Hope this helps :)
Top The Video Game Consoles & Games Experts
Alison Lofts
Alison Lofts
vince
Jun Salazar
Level 1 Expert
Are you a The Video Game Console and Game Expert? Answer questions, earn points and help others
