Turn the key to ON. Perform each of the following 2 steps within 5 seconds of one another.
Auto open the window 2 times.
Auto close the window 2 times.
Turn the key to the LOCK position. ...
Turn the key to ON. ...
Ever since a child died after being trapped by an electric car window safety has been built in - the motor current is monitored and if it suddenly rises as it would if it met an obstruction, it is designed to reverse.
Clearly your window motor is meeting an obstruction of some sort, probably in the door internal mechanism.
SOURCE: computer will not start
Choose Last Known Good Configuration. If that doesn't work, choose Safe Mode and then do a system restore to roll back your PC.
Any further questions, please use the comment box below to respond. Thanks.
Worldvet
SOURCE: Laptop wont start
Dear customer
your system OS is corrupted.so please installed oprating system newly XP or VISTA.try this
SOURCE: viewing mode reverts automatically to Dynamic fixed mode
Go to setup and reset to factory default. You will be asked the TV LOCATION (Store or Home). You must choose HOME. Hope it helps.
SOURCE: can't control passenger window in mazda 6
Passenger window lost programing. To reprogram, turn the key on, go to the passenger side and with the passemger switch run the window all the way down and hold switch in down position for 2 seconds, then run all the way up and hold in up position for 2 seconds, then repeat again within 5 seconds. Should work from drivers side master switch now.
SOURCE: My back automatic window went
My problem is just the opposite..sorta.. I can only get my window to close during the initialization process. It will not go down. I have replaced bothte regulator and motor wit the same results. Where can I get the pinouts of the switch and window motor/harness to verify the outputs/inputs?
