The RMT-TX1020 is not a remote that I find online. There is a Sony RMT-TX102U which is included with several models, including the KDL-32R500C. First, what input are you using on the TV? If you are watching OTA (analog or digital), then if captions are available, you should be able to press the Subtitle (CC) button below the Channel Up/Down buttons on the remote. There are three choices for Caption Display: On/Off/On when sound muted. You can also adjust the type of captions. In most cases, you'll want to use CC1 for both Analog or Digital captions. Navigate through the menu using the select (the center + button) and the arrow keys as with all the other menus. If you are using a set-top box (cable, streaming, Blue-ray player), you probably need to enable the subtitles or captions at that device. It could be in a hardware settings menu and not a function controlled by their remote control.
My current TV setup includes IPTV (fiber-optic internet). To enable subtitles, I need to go to the Menu and then to Settings. Then I enter a password provided by the ISP and go to the Hardware > Audio > Captions menu. On a neighbor's satellite dish receiver that served two TVs, enabling captions on the second TV (for their hearing-impaired relative) required enable captions in the Hardware settings for the primary TV.
The subtitle button usage is described on page 30 on the manual for this TV. Sony has the manual on the product support page: https://www.sony.com/electronics/support/televisions-projectors-lcd-tvs/kdl-32r500c. The current link to the manual is https://www.sony.com/electronics/support/res/manuals/4562/45622791M.pdf .
I hope this helps. Please add a comment with the video source for your TV if you want further assistance.
SOURCE: new problem with tv and Sony RMT-V202 Remote Control
Samsung makes AVOL you may want to try there codes. Hope this helps.
SOURCE: code for ferguson tv
These are all codes used by Fergies, hope one works for you.
0073 0287 0192 0190 0335 0238 0193 0109 0625
SOURCE: need remote control code for a Sony Dvd RMT-D175A
www.remotecodelist.com ............................................T.
SOURCE: how to program remote model # RMT-D130A
Found the manual online, here it is:
http://akamaipix.crutchfield.com/Manuals/158/158DVPN600.PDF
Go to page 60. Basically, just hold the TV Power button down, hit your manufacturer's 2-digit code, and release power button. If the code is right, the TV will power off and then back on again. The manual only shows numbers 01-19 in use, so I guess you only have to trial-and-error a max of 19 codes (which is ultimately faster than downloading and opening the manual)! I hope this helps you out.
SOURCE: What are RMT-B118A Insignia codes
Unfortunately, Sony did not elect to include Insignia codes in their remote control, so it is incompatible with Insignia TVs.
This remote is designed to control the product that it originally came with. If the remote has buttons for other product types (TV, DVD, etc.), it can control only Sony branded versions of these products. Please note that this remote may not be able to control all models of these other Sony product types.
