CODING LED (red) light flashes when a code is being stored or when a transmitter button is pressed. opener. The opener has to be initialised by the Reset button to make the O/S/C button operable. this button will move the door in the close direction.
https://irp-cdn.multiscreensite.com/86dd1279/files/uploaded/ATAGDO9v3TrioCodeSecuraliftMotor.pdf
SOURCE: Replaced door sensors now door will not go down and light flashes
The safety eyes are either installed wrong, or you have the wrong type. Craftsman (liftmaster) has what they they call old style and new style safety eyes. You can not interchange the types.
SOURCE: The garage door is closed and wont open, it beeps
Tries changes batteries in the remote,unplug the main operation motor,replug it,see if it reset it self.This a temp.fix,call the mamfucture for repair or replacement.
SOURCE: I have a Securalift Overhead
The courtesy light flashing five times means that there is a door overload. If this is a roll up door please have your tension springs serviced. If it is a one peace door make sure the side springs are not broken and have the door serviced.
SOURCE: flashing green light on garage
You don't mention any problems so I think what you are seeing is the LED that randomly flashes when everything is working as it should.
SOURCE: My securalift garage door opener gdo 2v7 will only
Check the limit switch for the open limit switch
