The back up battery has failed or is flat. It starts to work after sun up because the solar panel is feeding power to the system
Hi Bill,the system is not working on solar but pure Electricity
. Normally gate openers are low voltage and have a battery back up
if it is mains voltage , it goes through a transformer to power the electronics and a battery helps in mains failure . In any event call the installer to get it repaired
SOURCE: Wont start when cold (Mornings) When weather warms up will start
IF IS A DIESEL TRY REPLACEING THE GLOW PLUGS ??
AND IF ITS A PETROL CHECK THE DISTRIBITER CAP FOR CRACKS OF REPLACE COIL ??
SOURCE: when should I replace battery for Elite Robo-slide gate opener.
Sounds like its time to replace now!
SOURCE: Graco swing not working, I'm trying to open the motor box.
You need to remove the center of the part the connects to the chair. Use a thin screwdriver to pry it out a little, slide the screwdriver into the center and then pry each of the two tabs outward from the center. As you unhook it, you will be able to pry it out and then the attachment mechanism will pull off.
SOURCE: unable to program my new 2009 Altima Hybrid Homelink to my gate
The Learn Button is in a Silver little metal box that is in the opener housing but separate from the opener itself, pry off the case which kinda wraps around the reciever, it will say liftmaster of chamberlain the learn button will be in the reciever
SOURCE: i have an elite robo swing r900 gate opener. gate
first check you battery and make sure it is putting out 12v dc then if you have a solar power system check the red and black wire comming from the panel and make sure it is putting out 24volts. if you panel is not putting out the volts it caused your battery to die so replace your panel and battery and all should work fine. if your using a trickel charger do the same check power its putting out and make sure its correct and also check the 120v ac comming in to the charger. Follow the steps it deffinatly sounds like a power issue.
