There are many websites that are offering this just search it on google I have got delivered many of the things form different websites apart from that I use https://verifiedcouponcode.com/ to get free discounts and to many of the websites and this help me a lot to get numerous products for my household.
SOURCE: No Problem
This is "middle of the line" Kitchenaid as far as bowl size and motor strength goes. However, it is a great mixer that will probably fit your needs.
SOURCE: KitchenAid K5sswh mixer after replacing plastic gear-no power
Hi COVINIO. Yes, the "large black spring loaded magnetic screws on the sides of the mixer" are your mixer's brushes, which supplies electricity to the electric motor. (The black cap is the brush cover). I suspect that one or both of the brushes is (are) not seated properly. Did you remove the brushes to replace them or were you just inspecting them, when you replaced your plastic worm gear?
The brushes need to be installed so that they both seat correctly on the armature's commutator. See the illustration below:
I'd suggest removing them again and making sure the concave contact face rests completely on the armature’s commutator. If you've turned it 90 degrees too much, it won’t seat properly and you get no power to the motor.
It would also be helpful to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4) and then check to verify this matches your mixer model.
Turn to pages 6 & 7, titled “Motor And Control Parts”, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. Locate Illus No 47, Brush holder assembly that includes #28, 32, 33, 34 & 46 which is the brush holder insert, and Illus. No. 29, brush & Spring assembly respectively. The illustration along with the picture above regarding the orientation of the brushes should get your mixer powered back up and operational. Good luck! I hope this helps. Howard, Burke, VA
If this solution has been helpful to you, please rate it, thanks! -hslincoln
Testimonial: "Dear hslincoln,Thank you for your very helpful link to diagram that showed exactly what to. It was fixed within 3 minutes"
