Televison & Video Logo
Marion Wallace White Posted on Feb 14, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you save settings on my Cello TV. The remote is rcc004-04. Don't know TV as it's on wall. It's turning off every 4 minutes. I've set timer to off, and sleep timer to off, but I don't know how to save the settings so it won't turn off.
Attique-ur-Rehman
Level 3:
Top Expert:
  • Televison & ... Master 2,677 Answers
  • Posted on Feb 14, 2020
Attique-ur-Rehman
Level 3:
Top Expert:
Answers
2677
Questions
Helped
879662
Points
8006
5 Related Answers
Rommel Balcita
  • 749 Answers
  • Posted on Dec 05, 2007
SOURCE: Can,t be able to turn my tv set to video mode
try some universal remote controls!
Anonymous
  • Posted on Jul 29, 2009
SOURCE: Can't set the sleep timer
I have the same problem. Does anyone have a fix?
Anonymous
  • Posted on Mar 06, 2010
SOURCE: Olevia TV Remote doesnt work Sleep Timer
The TV is in 'showroom mode'. To fix: Click: Menu --> Picture --> Mode --> Power up then select: Home. Then click menu until you exit the settings. You will now be able to use the sleep timer.
Anonymous
  • 1116 Answers
  • Posted on Jun 09, 2011
SOURCE: I have a raindrip 2
You can download your instructions here:
R673CT Digital Water Timer Installation Manual
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Anonymous
  • 7 Answers
  • Posted on Jun 23, 2011
SOURCE: I bought a Sigma BC
It will be auto shut down,
dont touch it for 5 minutes and dont spin the wheel with the pick up on it!!!!
The clock will stay on but all other details will disappear.
What is the sky remote code for a cello model c20234f-led ?
Turn on your Sky Box and TV.
On your Sky Remote, press the TV button.
Simultaneously press the Select and Red buttons until the red LED on your remote blinks twice.
Enter one of the following 3-digit remote codes for Sky TV:
2274
2169
1874
1798
1872
1873
The light on the remote should flash twice. If it blinks only once, repeat the steps with the next code.
Press the Standby button on your remote. If your television turns off, press the Select button to save the setting.
Turn on the TV and press TV Guide; if the TV Guide list displays on the screen, the programming was successful.
Remember that there are multiple versions of Sky Remote Controls available, so ensure you have the most recent version. If you encounter any issues with the 3-digit codes, you can also try using a 4-digit code. Here's how:
Repeat steps 1 to 3.
Enter the 4-digit Sky remote code for your TV brand.
Press the Standby button. If your TV turns off, press Select to save your settings.
Check if the TV Guide displays successfully on the screen.
Sky TV Remote Control Codes
2helpful
2answers
What causes Sinotec SWTV-20AE to switch off on its own?
There are a couple of possibilities. Many modern gadgets have a power-saving setting. This turns off the unit after a period with no human interaction. (Remote button presses for set-top boxes or TVs, for example.) You'll need to change this in the settings. (I didn't see the SWTV-20AE manual online to find the menu tree.)
The other possibility is over-heating. Make sure there is nothing blocking the airflow around the unit. Remove any dust and dirt from any ventilation holes.
I hope this helps.
Analog white-westinghouse tv has blue screen and no sound. Connected to digital converter. screen does not change and after 5 minutes the tv shuts off
the glitches could have fried part of the tvs main chip
i have had it happen to me a few times and or it was a fuse
Remote doesn't control on/off,volume or channels
Remote won't workThe most common reasons the remote won't work is that the batteries are dead or it hasn't been programmed properly. It's often easy to fix. Here are the steps to take to troubleshoot the problem.
Make sure you have a clear path between the remote and the infrared eye on your equipment. Clear any dust or debris that may be covering the eye.
Try unlocking the battery-saving mode. When a button is pressed for longer than three minutes, the remote goes into battery-saving mode. Press the SAT mode button at the top to unlock it. Your remote should work properly.
Check the batteries. When you press a mode button, does it light up? If not, you may be out of juice. Check to make sure they are in the right way, with the metal ends making good connections with the metal in the remote. If they're in correctly and you still don't get power, try replacing them. They may be dead.Learn about batteries
Check to make sure the remote is programmed properly, which basically means you reprogram it to work with your receiver, TV and any other components. Start with the receiver and work your way through programming each component that isn't working. We tell you how to program remotes in our guide to remotes.Learn about remotes
Still no go? You may have an internal problem with the remote. You'll have to talk to a Shaw Direct customer service representative. Call 1.888.554.7827.Be prepared to tell us:What components you have.All of the steps you've been through to try and solve the problem yourself.Can't change channels on receiverThis is almost always caused by a programming problem with the remote. Here are the steps to take to troubleshoot the problem.
Make sure you are in SAT mode. The receiver will only change channels when the remote is in the correct mode.Look for a timer. If you have a timer set, the receiver won't let you change channels. This ensures you don't miss recording a program with an external device. If a timer is set and you want to watch another channel, simply turn off the receiver and turn it back on.Learn about timers
Make sure the problem is with the remote and not the receiver. Try the buttons on the front of the receiver. Try to change channels. If your model doesn't have channel buttons, try to turn the machine off. If you can't change channels or power off, the problem is with the receiver. Try unplugging it for two minutes and plugging it in again.
If you can change the channels or power off, the problem is with the remote. Press any mode button on the remote. It should light up. If not, you probably have low batteries. They should be replaced.
Try unlocking the battery-saving mode. When a button is pressed for longer than three minutes, the remote goes into battery-saving mode. Click on any of the mode buttons at the top to unlock it. Your remote should work properly.
Try re-programming the remote to talk to your receiver.Find the manual for your remote control
Check to see if your Shaw Direct Receiver is using the same remote control address as your remote control.If you are using the DSR 319, HDDSR 505, or HDPVR 530 receiver press the Options button on the front panel of your Shaw Direct receiver. An options menu should appear on your screen. Using the direction keys on the front of your receiver navigate to 6 - System Setup and then press the Enter button on the front panel of the receiver. Using the same directional and Enter buttons go to 4 - System Setup. Then 3 - Installation Settings. Followed by 2 - Remote control Address.If you are using a legacy receiver such as the DSR 315, DSR 405, or any other receiver with front panel buttons, press the Options button on the front panel of your Shaw Direct receiver. An options menu should appear on your screen. Using the direction keys on the front of your receiver navigate OPTIONS and then press the Enter button on the front panel of the receiver. Using the same directional and Enter buttons go to 6 - Change System Settings. Then 3 - Change Installation Settings. Followed by 2 - Set Remote Control Address.Follow the on-screen instruction to reset the remote control address on your receiver and remote control.Check the back of your remote, if you own the IRC/URC 550 or RT-U50 remote controls you will need to enter the remote control address differently from what is displayed on screen. To program these remotes, hold the ENTER and MUTE button on your remote at the same time until the mode buttons at the top start to illuminate then enter the last three digits of the number displayed in "Current Address" column on the screen, then press the MUTE button to lock in the code. For example: If the remote address on the screen displays 0002, you would hold ENTER + MUTE until the mode button illuminated and then enter 0 0 2, followed by ENTER on your remote control.If you own the IRC 551 or URC 551 remote control you can follow the instruction depicted on the screen, but you must substitute the follows numbers in place those specified: 00869 for 0000, 01870 for 0001, 01871 for 0002, 01872 for 0003, 01873 for 0004, 01874 for 0005, 01875 for 0006, 01876 for 0008. For example: If the remote address on the screen displays 0003, you would hold the SAT button until it flashes, press 01872, then ENTER, to lock in the new code.Still no go? You may have an internal problem with the remote. You'll have to talk to a Shaw Direct customer service representative. Call 1.888.554.7827.What components you have.All of the steps you've been through to try and solve the problem yourself.Can't control TV volumeThis is almost always caused by a programming problem with the remote. Here are the steps to take to troubleshoot the problem.
Press the volume button on the remote. The TV mode should light up. If not, you probably have low batteries. They should be replaced.
If the SAT button lights up, you are in the wrong mode. Press TV and try again.
Try re-programming the remote to talk to your TV.Find the manual for your remote control
Still no go? You may have an internal problem with the remote. You'll have to talk to a Shaw Direct customer service representative. Call 1.888.554.7827.What components you have.All of the steps you've been through to try and solve the problem yourself.Thank you for using Fixya, Hope this will help your problem.Don't forget to rate me.thanks,Reymond
9helpful
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Black screen and no sound after a few minutes.
First, here is a copy of your manual in case it is missing.
http://www.warrantyweek.com/library/ww20061219/panasonic-th42px60u-manual.pdf
Next, check the settings of the sleep timer.
Select on the remote:
Menu.
Timer.
Sleep.
See if there is a time setting in there. You may also find a shortcut from the remote labeled "Sleep".
If this fails to resolve the issue, you can always reset to factory defaults. To do this, select from the remote:
Menu.
Setup.
Reset.
Hope this helps. Be sure to let us know how this helped.
2answers
Screen won't display
I found your site confusing. If you had read my post, you would have noticed that my problem referred to a 15" flat screen 'CELLO' .TV/DVD combo. I had sound but no picture. When switched on, the screen lit up and the word CELLO appeared then the sreen went black
27 in samsung tv
TRY UNPLUGGING THE T.V. FOR TEN MINUTES. THE TRY THE BUTTON ON THE FRONT OF THE SET. YOU SHOULD BE ABLE TO GET AN ORIGINAL REMOTE FOR AROUND $40 .
DON.
3answers
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
