SOURCE: Problem with my LG monitor L194WT
First change the referesh rate for your monitor. If that works, then you dont have to change the resolution. If that does not work, try increasing the rate again. Once you can get the game, then try to change the resolution from within the game options, if necessary..
SOURCE: I am trying to install
You need to lower your PS3 video resolution to the TV native resolution. Try at lower resolution first and go up from there. Right now it is too high for the TV.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
SOURCE: When I hook my ps3
Turn the system off, then push the power button for 5-10
seconds. That resets the video to the minimum setting.
Or
*WITH NO DISC INSERTED* If there is one, eject it and turn the system
off so I can show you from a system start with no disc. This IS using a HDMI cable as well
1)Power on system; do NOT push any buttons on the controller!
2) Over 4 to the left
3)9 down
4) Click 'X' once
5)Click 'X' again
6)Click 'X' again
7)Click 'X' again
That should bring you to some settings list that makes sure that the settings you clicked were what you want.
Good luck.
SOURCE: i recently bought a 22"
I have the same ******* problem hold the button that turns. On your ps3 till it beeps then turn your screen back on
SOURCE: when i plug in the
You'll have to change the resolution on your PS3 to match your TV resolution by going to settings>video settings.
hi,
maybe when you changed the video format the resolution of the screen was changed or
the new format needs another resolution.
try to change the resolution of the screen
daniel
https://www.rylwy.com/
