Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
SOURCE: i need the 3-digit code for my sharp tv code
Here is a link to an extensive list for your 3 digit code to use with Chunghop
preprogrammed remote controls it includes scanned copies of 6 different
versions, plus a cross-reference chart. I hope this helps, if it does please let me know by giving me a yes helpful rating~
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=chunghop&dv=universalremote&md=chunghop3digitcodescollection&kw=&st=&ar=&dt=&so=&pg=1&file=others/chunghop/chunghop-3digit.zip
SOURCE: i forgot the code in my keyin universal remote i use sony tv
039,029,019,046,027,025 are the codes to check. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and setup instructions to some popular model remote controls are given.
SOURCE: What is the code of Pensonic LED TV in Model 2424 in Keyin Universal remote control
0182,0188,0159,0153. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
SOURCE: ihave keyin rm 133e universal remote and ineed a code panasonic tv
