If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
SOURCE: 40 inch lcd blue line vertical
The display screen is made of a matrix of elements connected to cables
along the side and top. On your unit, some of these many, tiny
connections are making contact intermittantly thus losing the elements
in that area. These contacts are held in place with just pressure and
if that is disturbed, you lose that line of elements. Try squeezing the
cabinet of the TV on the outside at the top in the area of the loss and
see if that makes a difference. May have to go inside and see if the
contact assembly is disturbed or warped or something.
Hope ya fix it!
SOURCE: Red line across top half of screen
Uh-Oh.. Sounds like the BGA RAM in the video circuit. (These units are Intel based and Core 2 duo if posted correct).. We can repair if you need help and its under warranty and sorry its not a home remedy situation..
ikenfixit.com
SOURCE: Black Vertical Stripe
try doing white wash feture in options see if u can get it out this way 1st before having to take aprt cheak cables are using old style sumtimes they do get glitch do factory reset thx for using fix ya . nick
SOURCE: Vertical line on side of LCD TV
Modern televisions have screens divided into sections. Each section controls all the rows in its area, and it is controlled by its own video separate video driver. If you are missing a line in a section, then a problem has occurred with the driver board in that area. It will be pretty expensive to fix, I hope your warranty has not just expired!
