Only reset you can do is unplugging power cord for 10 minutes.
The control panel it is probably faulty and in need for replacement.
SOURCE: Kenmore side by side runs then stops
When you say runs awhile, how long? What is shutting off all power or just compressor?
If the clean light flashes 7 times, pauses then repeats...
If the dishwasher doesn't sense a water temperature increase, it will
stop working and lock the functions (clean light flashes 7 times, all
buttons are non responsive).
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all
the lights will turn on briefly and the machine will start a diagnostic
cycle. You can press cancel or let the diagnostic cyle finish (1-2
minutes).
You should now be able to run the dishwasher as normal.
If
the issue returns, you could have a problem with the heating circuit
(ie. element, thermostat or wiring). It rarely happens but it could
also be the door switch not engaging properly when the door is closed
(slightly bend the door latch down making sure it doesn't hit the door
when you close it).
SOURCE: microwave stopped heating
I had the same oven for one and a half years and had the same problem. Had the sears repairman come out and he said the magnetron burned out and needed replacing for $285. It was never under warranty with the warranty that came with oven. I couldn't believe it! We had an independent repairman look at it and he found a design flaw that causes the magnetron to blow. If you replace the matnetron (megnatron?) it will work for awhile, maybe, but then just need to be replaced again. It's cheaper to buy a new microwave. In fact, I got out our old microwave that's over 20 yrs. old and still works--just isn't as fast and as new ovens. Good luck!
SOURCE: I am thinking of buying used kenmore model
Please see the following Sears Parts list and Owners Manual.
The loaded weight is 260 Lbs.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.49722992
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0710496.pdf
Water is 8.35 pounds per gallon. Plus the weight of your clothes.
