Sync-ing problem while trying to sync my e280 with rhapsody the screen glitched and the player restarted and kept restarting everytime rhapsody reconized it. Then i tried to sync it with windows media player and it said that there was an error with my songs the the player froze completly... help??
Rhapsody will not work on an iPhone unless you jailbreak (which is not advisable). Apple wants you to use iPhone. You can use music you bought from Rhapsody and import it to your iTunes and then sync. I used to work for Apple Tech Support.
Make sure your Rhapsody subscription is paid and up to date - if it ever lapses you will lose the songs. also, check out the License tab under properties for the songs that failed - the license may have a fixed-term/expiration date and can no longer be synced without paying $$. Rhapsody sucks like that.
the e280 8gig it doesn't come with a cd instalation, it only works for transfer music in media plalyer 10 or 11 sync. another way to tranfer his drop and drag to do this open my computer then open the device u will see file just as music,photo, videos drag and drop the musica files into the file. if poppoed up apear it happen to me too the only thing i did was switching usb ports to a diffrent port. www.scandisk.com for and updates select downloads. it will said drivers downloads select sansa firmware updates but before it has to be unplug. when download finish u need to restart then plug e280 open sansa update in desktop it will show u e280 if new updates are availble. also check the system requierments for compabilities. hope this help if not u can contact sansa coparation there listing in support. hope this help,
You must be in MTP mode, create a sync list in WMP, then drag the play list to the sync list of the e-280. it will create the new playlist on the e280.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced. Download the Sansa Recovery Tool from the Sansa website. Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything. Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp If these fail, then: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version). You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer. -Tha Mp3 Doctor
12259-
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
-Tha Mp3 Doctor
To get rid of that message, you need to connect your Sansa to your computer and open the Rhapsody software to "deauthorize" your Sansa (assuming that you're not going to be using the Rhapsody service).
The following URL gives you two options on how to deauthorize your device (look at the bottom section of the page):
http://home.real.com/product/help/chandler/en/instruction/auth_deauth_pd-textonly.htm
i'm having a similar problem. every time i sync new music my computer tells me its on, but the tracks aren't on the player. it also refreshes every time i turn it on, which takes forever amd is getting really annoying. could this have something to do with my new microSD card?
