My 44 inch zenith lcd tv has recently developed a yellow spot in the center. is it time to replace? or is it cheaper to fix? the stupid thing is only 3 years old--thanks!
CALL LG I HAVE THE SAME PROBLEM WITH MY TV AND THEY EXTENDED MY WARRANTY FOR A NEW LIGHT ENGINE I HAVE HAD MY TV SINCE 2004 AND THEY PUTIING A NEW LIGHT ENGINE FOR FREE IN 2009
This TV is under a class action lawsuit.
LG has to replace the light engine or the tv if the light engine doesnt work.
They are really good abotu getting the problem solved within 15 days per the settlement.
I had the light engine replaced and it didnt fix the issue so I got a new TV.... LG is going to batt with this........because the Classaction lawsuit or not.... good to do business that way.
I have the same yellow spot with my Zenith 52 inch rear projection LCD. What should I do!
If you have a purple/blue trim across the bottom and yellowish at the topit is because there needs to be shims added to properly align a lense in the light path. This is a fairly simple fix and a light engine tech should be able to correct this problem in under 1 hour.
The Purple/blue trim along the bottom is that the light engine needs to have a couple of shims added to align the lense. This is a fairly easy correction and can be done in under an hour by a light engine tech.
This tv sucks. I have a purple/blue trim along the bottom of the screen and a yellow trim along the top. Now it's appearing in the center. Please help
This is a common problem that is caused by the filter that goes with the blue LCD. Such filter is part of the light engine, I believe Zenith sells the complete light engine only(around $800), while I don't think the filter cost more than 99 cents to manufacture. If you want to replace the light engine I think matelectronics.com has a good deal on that.
same yellow area lower center screen. end of bulb life light came on so we replaced bulb. screen still yellow. what now ?
same problem, 3 years old.
Same problem w/ yellow circle in center of picture. 3 years old. Have a call into Zenith service center to find out what's going on.
I have the same problem. My TV is exactly 3 years old. Fortunately I bought a 4 year service contract with Best Buy and they are coming this Friday to service it. I will post the solution their technician gives.
I Have a similar problem with my Zenith LCD TV ,except
I get blue spot in the lower left corner of my screen, sometimes it moves around. Weird!
tv works fine just a yellow tint in middle of the screen , can I fix this at home my self ? is there a bulb to change or an adjustment to fix this ?
haven't made any moves to fix this yet .this is a zenith 54" rear projection tv model R50V26 HDTV
I have a e44w46 zenith lcd with a yellow spot in the middle. I need a bulb; however, I dont want to waste money if the yellow spot wont go away once bulb is replaced.
Hello out there. I have a Zenith E44W46LCD. The picture is dark with a yellow spot in the middle of the screen. Is this a fix that can be done at home or needs a pro.? Thanks
I have the same TV, same problem. What do I do to fix it?
The light engine was replaced on my tv and now the picture alignment is off about two inches to the right. I tried to have the company come back out but they said I waited too long. Is this easy to fix?
Same problem, expanding yellow ring. Called LG this morning, said that they would replace free and would have someone call me to set it up. Stay tuned, but sounds like they plan to take care of it. Anyone else out there had the same experience? Did they call you?
