Sony KDS-60A2000 60" HDTV Logo
Posted on Sep 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony rear projection tv picture going on and off
Sony kds-60A2000 rear projection tv picture going on and off every minute or two. It appears that the lamp is turning itself off - no indications on the front panel or that the lamp is old. I've taken the lamp out, cleaned the connector and reseated it - no difference.
Anonymous
Level 3:
  • Master 556 Answers
  • Posted on Sep 21, 2009
Anonymous
Master
Level 3:
Answers
556
Questions
0
Helped
154165
Points
1096
Change the lamp is is too weak to operate properly.
Tv is 6 years old - greenish tint to everything KDS-60A2000
it is, called a optical light engine and that is about the most expensive part in the set.
tip
Sony KDS-60A2000 Service Manual
Download Sony KDS-60A2000 HDTV Service Manual
Models: KDS-50A2000 / KDS-50A2010 / KDS-55A2000 / KDS-60A2000 / KDS-60A2010
Have you misplaced your Sony KDS-60A2000 HDTV Service Manual?
Would you like a digital, searchable, pdf version of the Sony KDS-60A2000 HDTV Service Guide?
Follow this link (& click FREE) to download a pdf version of the Sony KDS-60A2000 HDTV Service documentation.
I hope that helps.
__________________________________
on May 08, 2010 • Televison & Video
tip
I hope that helps.
1helpful
Sony kds-60a2000 power light flashes 5 times, no picture
5 flashes - Lamp Driver - (lamp driver faulty)
This is the error code that usually means the ballast (it is the power supply for the lamp) is bad.
SD TECH
My sony is turning on and off when I turn it on. The picture and sound appear and disappear. What is wrong and do you have the part..
The most common cause of picture disappearing and returning in a Sony LCD Rear Projection TV is a faulty bulb. Replacing the bulb is the first step in troubleshooting this type of problem in KDS-60A2000 and all other Sony Rear Projection LCD TVs.
Sony Lamp Gallery
shows all Models and Lamps for Sony Rear Projection LCD TVs. KDS-60A2000 uses XL-5200U Lamp.
easyab
Picture on my sony kds 60a2000 tv goes out and then comes back on repeatedly, what could be wrong
you have to replace the bulb what happening is the life hours on the bulb is almost over just replace the bulb soon or later you will see a red flashing light sometimes that's indicating the bulb needs to be replaced
12helpful
2answers
The picture appears to have a green tint to it Sony KDS-60A2000 3 yrs old
The optical block is failing. Contact SONY for a replacement. They have extended the warranty or replace the sets
My Green power LED is flashing continuously.. no
Ur power supply board is dead,need a new one.
3helpful
Sony KDS-60A2000 projection TV: power led blinks 4 times
the projector bulb has gone out you need to replace it.
hope this helped
please rate well
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Sony Lamp Cycles Off and On
Bad lamp>replace lamp and reset timer in customer menu .Common problem with SOny.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
