Question about Kenmore Elite 45986 Front Load Washer
How do I get rid of the stinky smell of my front loader?
We cleaned the pump and trap got rid of the F2 and everything is working fine. How do I get rid of the smell?
    Sergeant:
    Champion:
  • 219 Answers
The smell comes from your front rubber boot you must replace it toget rid of the smell.The water collects in the inner part of the boot and and sits there till it smells hope i helped
Posted on Sep 20, 2009
6ya staff
SOURCE:
What makes a kitchen sink stink?
There can be several reasons behind stinking of the Kitchen Sinks. Here is the list of them and the tips to resolve them:
  • A rotting food smell from junk stuck in the garbage disposal or drain: Use vinegar and baking soda, run ice cubes through the disposal, put lemon or orange slices in the disposal.
  • Sewer smell from gas leaking in through the drain trap :High pressure can force its way through the water in the trap and low pressure can siphon out the water from the trap.
  • Bacteria: One reason for a smelly kitchen sink can be the presence of bacteria in the drain pipe. To get rid of the bacteria you can either use baking soda, vinegar, or a commercial drain cleaner or bleach.
Even if you do not get rid of stinky smell then you can contact any professional plumber online for help.
May 30, 2018 | Home
Standing water in front loader how to fix
More details about where, when, how (and how much), etc., might be useful.
I'd check easy things like the drain hose, to make sure it's not clogged. But the most likely thing is that the filter cup has gotten clogged or the drain pump is dead.
To check out: Get a wet/dry shop vac. Hook it up to the drain hose to suck the water out of the machine and save a lot of mess.
Remove the bottom front panel. The drain pump on my Duet is front center bottom... easy to get to. There's a plastic handle to unscrew if I recall correctly, which brings out a sort of plastic cup filter. You might find enough change to buy yourself a cup of coffee. Clean it out. If it wasn't really clogged up, the problem is either something stuck in a hose, or a failing/failed pump. Check the hoses first; if it's not them, I'd order a new pump.
May 27, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Door won't unlock whirlpool wFs1073dd front loader
If it has water in the the machine, it has a safety feature that will not allow the door to unlock. There is a manual release but you have to take the bottom kick plate off. Unplug the washer. Then reach up on the right side of the washer and you will feel a plastic lever about the size and shape of a nickel pull down on this lever to release the door. If it full of water i would clean the pump first to get rid of the water. you can clean the pump by taking off the kick plate and you will see a pump with a lid with a handle on it. you can unscrew this and it will have a trap attached to the back of the lid. pull the trap out and clean any debris out then screw it back in. make sure to have buckets and towels handy once you unscrew the lid any water in the machine will fly out at you. the easiest way to avoid this is to clamp the hoses that go to the pump.
Aug 24, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Strong Odor, almost organic smelling, coming from my Fridgidaire Energy Star stacked Front Load Washing Machine, 5 cycle, Heavy Duty Model# FTF530FS1, Serial # XC90201067. It is in the townhouse that we...
This smell usually comes from items caught in the hose. If you can remove the bottom front panel, (usually 2 screws holding this down) then you will see a rubber acordian piece attached to the water pump. If you remove and clean this the smell should not remian. I just removed mine and found many coins and a huge ball of stinky lint, hence the smell. Good Luck!
Jul 21, 2011 | Frigidaire FTF530FS Front Load Washer
Do not buy an LG Tromm front loader unless you want stinky, moldy clothes! The first few months, I LOVED this washer, but now I think the machine is possessed by smell demons! I've tried everything, but...
Stinky clothes are usually the result of washing in cold water. Cold water will NOT kill bacteria.
Add one cup of vinegar to the wash before you start the machine - try it.
The vinegar will kill the bacteria during the wash. Your wash will NOT smell of vinegar.
The dryer level of dryness on most auto dryers needs to be set three clicks toward + on most machines. LG is no different.
Apr 02, 2010 | LG WM1812C Front Load Washer
Maytag Neptune front load washer ??? Is there a filter ???
I have a Maytag front loader MAH6700AWW. I just pulled the pump lastnight because it had a quarter stuck in it and was making a terrible grinding noise. I was shocked to discover that there is absolutely no filter trap on this machine. If anything gets past the rubber boot, and coins can and do... you need to wish for luck in that you do not wipe out your pump. I was shocked that this machine had not filter trap between the pump impeller and the tub drain. All newer machines have these. The LG and most have a trap door on the front you open to access the trap. Some of the earlier front loaders required that the bottom front panel be removed. No such animal on this Maytag. Probably yours as well.
Apr 19, 2009 | Maytag Neptune MAH6500A Front Load Washer
F2 error code
check your drain hose for kink,,when you cleaned filter did you check for coins in the impeller..also check drain pipe for slow drain problem,,check the pump connection and make sure its not slipping off..onthejob
Jan 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Towels smell oily and moldy--really stink
Don't use fabric softener. I had the same problem and read somewhere to stop using the fabric softeners. I don't know why but after about two cycles (they smelled really bad) it worked! I always used fabric softeners with out a problem but one day I just started getting REALLY smelly towels. I always take my wet wash out as soon as the cycle ends and dry it completely so I was surprised when they smalled so bad. Give it a try.
Jan 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Laundry
Same problem with my front loader. You have to make sure to clean out the rubber trap in the front regularly. it seems to collect alot of hair and plug the drain hole. also it helps to leave the door open when you finish washing to further reduce the stagnant water smell. Use fabric softener for the towels!
hope that helps.
Aug 02, 2008 | Kenmore Elite HE4 Electric Dryer
Stinky towels
Mildew odor in towels in almost invariably being transferred from the washing machine. The clothes washer must be cleaned first then clean the smelly towels and laundry. To compare washer cleaners watch this video of Affresh and Smelly Washer...
http://www.youtube.com/watch?v=Ua6OJPn0-fU
Apr 19, 2008 | Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
614 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
