Frigidaire washer GLTF2940ESO starts to fill with water then water shuts off and the washer doesn't do anything else. The water is working properly because I checked the hoses. Not sure what is wrong, no error codes come up.
That is not the solution.
Start the machine and immediatly press the "Start" and "Pause/cancel" button at the same time. Then you will get and ERROR code. Look on the cheat sheet packed with the machine to find out what is really wrong. That will give you the real answer.
Appliancepartssuppliers.com
Check motor brushes, may be worn so motor will not turn under load, if not that could be more serious, faulty PCB or timer,
Will it spin on spin setting? call for approved engineer if unsure
