Compaq cq40 is one particular model from compaq which is literally designed for vista and when you want to install win xp ;it doesn't work becoz the BIOS block it;the only way out is to downgrade the system BIOS which is a risky thing.check your bios model and version and google for a lower version and download it and flash the ealier BIOS.gooogle more on How to downgrade BIOS
1. Turn on the computer and open the DVD player.
2. Load the Win XP installer and then reboot again the computer.
It would give you a message "Hit any key if you don't want to boot from the CD", in this case, DO NOT hit anything so that the computer would boot using the CD.
3. Run through the installation (the instructions should appear on the screen).
4. Put the product code when ask.
5. Win XP should be installed now.
You should have also the necessary drivers for the video, sound and LAN card so that you could attain the best performance of those components.
Have a great day!
Go here
http://www.laptops-drivers.com/compaq/how-to-install-windows-xp-into-compaq-cq40-101tu.html
remember to turn off the sata in the bios until you finish install. XP cant handle sata drives correctly.
First before doing anything, make sure you have the software(drivers) for this system. You will need it. http://driver-pro.com/related/english/hardware-drivers/?a=12072&gclid=CL-wgObIgZ0CFQ_xDAodpye7ag&hit=1
Method 1: Perform a clean install of Windows XP
loadTOCNode(2, 'resolution');
A
clean installation consists of removing all data from your hard disk by
repartitioning and reformatting your hard disk and reinstalling the
operating system and programs to an empty (clean) hard disk. For more
information about important things to consider before you partition and
format you hard disk and how to partition and format your hard disk by
using the Windows XP Setup program, click the following article number
to view the article in the Microsoft Knowledge Base:
313348
(http://support.microsoft.com/kb/313348/
How to partition and format a hard disk in Windows XP
To perform a clean installation of Windows XP, follow these steps:
If
you have successfully installed Windows XP, you are finished. If these
steps did not help you install Windows XP, go to the "Next Steps"
section.
Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.
All u need to desable the SATA option in the BIOS. if you do it there is no difrence then the general system installation.
SOURCE: need audio driver of compaq presario V6000
Here's a link to the audio drivers for the V6000. You will need to download both that are listed under audio.Don't forget to rate me (fixya). thanks
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=1842078&lang=en
SOURCE: compaq presario cq40-145tu some times audio not
1. Upgrade Service Pack 2 to SP3, can be downloaded from Microsoft website
http://download.windowsupdate.com/msdownload/update/software/svpk/2008/04/windowsxp-kb936929-sp3-x86-enu_c81472f7eeea2eca421e116cd4c03e2300ebfde4.exe
2. Download and Install MS UAA - Microsoft UAA Bus Driver for High Definition Audio - KB835221.exe
http://files.filefront.com/KB835221exe/;6068840;/fileinfo.html
3. Download and install the latest IDT drivers - HP IDT High Definition
Audio CODEC Driver 6.10.6087.0 Rev.B from
http://drivers.softpedia.com/progDownload/HP-IDT-High-Definition-Audio-CODEC-Driver-61060870-Rev-B-Download-75824.html
Restart Laptop, you are all set!
SOURCE: how to compaq cq40-301tu install windows xp
You need to have SATA drivers, before installing Windows XP. SATA drivers are not included in the CD, unlike Vista. There are many websites which explain how to include SATA drivers in your CD. You may have to find right SATA drivers depending on your laptop.
SOURCE: HOW TO INSTALL XP IN COMPAQ PRESARIO CQ40-108TU
hi rohit this is saurabh here....i have the cd in which the driverd r pre loaded......so u contact me i will send u the cd....my no is 09896038291
Download link for the windows xp sp2 i create for compaq presario cq40.
http://dl.oamo.com:8099/software/0704/13...
