When i'm switching on my nokia 3110 classic it shows the NOKIA sign then after that it shows the NOKIA START UP TONE (the two holding hands together) then after the strtup tone it shows the standby mode screen then after that the phone restarts again and again when it is showing the standby mode screen !!! how could i fix ds .. ?? NEED HELP !!! IMMEDIATELY !!!
The Problem with Nokia 3110c – Switching off and automatically restarting
This is what happens. Nokia 3110 hangs, gets switched off and
restarts randomly. More often, it restarts around 3 times or so and
then gets switched off.
Possible Causes and Solutions
Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500
KB, so as to keep things running smoothly on your phone and prevent
Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have
reported that the phone restarts automatically when they try changing
display themes on the phone.
Solution – Don’t get your phone loaded with too
many themes downloaded from the internet or atleast, don’t switch
themes frequently. These themes, mind you, also load up things into
your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data
cable (or) Updating Music Library – A few people have reported that
their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider
converting all your MP3 music files to WMA and then store them on the
memory card. Some users suggested this.
Also try this:-----
It ll work . you dont need to go 4 the firmware v5.05
If ur phone restarted 3 or 4 times and switched off automatically. Try this
method
1] Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu
[default security code:12345]
{i know most of people have done this thing,but remember u have 2 go
with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]
between 470kb - 499kb.
Now surely ur 3110c working fine about 5
months.During these time u can
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime.
but remember below DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times
and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Hi i have use Activate default in all applications in nokia 3110 mobile.
after when i start my phone nokia3110 its blink 3 time then off. please tel me the solution
Its the problem of virus.ple romove the memory card than start
Hi, my nokia 3110c is restarting when i turn on and then off plz.. help me to fix this problem
Hi, my nokia 3110c is having a problem, the problem is that whenever i'm switching on the phone it is showing NOKIA logo and the display blinks three to 4 times then again it goes to off ....plz help
