pinched the single red power wire when in stalling the starter, repaired the wire , replaced the fusable links, if you jump the selonoid it will turn starter , everything in car works except when i turn key to crank engine i get nothing, no click , starter does nothing , have power to starter , power out of starter to ingnition switch, i don't think i am getting power to the selonoid from wire on s post of selonoind. pinched the single red power wire when in stalling the starter, repaired the wire , replaced the fusable links, if you jump the selonoid it will turn starter , everything in car works except when i turn key to crank engine i get nothing, no click , starter does nothing , have power to starter , power out of starter to ingnition switch, i don't think i am getting power to the selonoid from wire on s post of selonoind.
You can't post conmments that contain an email address.
Check the purple wire coming out of the ignition switch and ensure you have power coming out of it to the starter and ensure that the rod from the key to the switch is fully activating the switch to send power out.Check the purple wire coming out of the ignition switch and ensure you have power coming out of it to the starter and ensure that the rod from the key to the switch is fully activating the switch to send power out.
It is more than likely in a fuseable Link coming off of the battery or off of the alternator causing your power lose. How many grounds did you check, because there are at least two grounds on the car. The first one is the main ground off of battery and the second one coming off of the back of the engine.
You should be able to get diagram from auto parts suppliers and performance parts suppliers. Call your local deakership and see if they will email the schematics.
It depends if you have a high volume oil pump or a factory one but either way if your pressure is between 35 psi to 60 psi you have no problem this is at road speed your oil pressure at idle should at least 25 and 30 would be better
