I have an old arbor electric guitar strat copy. Is it normal for the truss rod to protrude out of the headstock. Mine does by about an inch and interfers with the 3rd and 4th strings?
If you are unsure about the truss rod or if it needs adjustment, visit www.learnguitarsetups.com for a step by step guide on how to adjust them. If the truss rod is protruding out of the neck so far it's interfering with the strings, it likely needs to be adjusted! Either that or poorly made/designed guitar - just as likely!
No the truss rod is usually in more than that. Take it to a reliable Musice Store and they shold be able to adjust it for you.
SOURCE: guitar truss rod dilemma
The truss rod must be too slack then.
Is the sound ok? Does it play ok?
In it's current state the truss rod is doing nothing.
If the guitar is sounding ok and playing ok, then the next time you change the strings pull the truss rod out and throw it in the garbage.lol
Seriously though...just pull it out and put it aside.
If,however,the guitar is not sounding ok then try tightening it.
If you're unsure about how much to tighten it then I suggest taking it to your local music store for help with that.
