Aiwa HV-MX1 VHS VCR Logo
Posted on Sep 22, 2009
Aiwa HV-MX1: tape won't eject from VCR and it switches off.
I have an Aiwa HV-MX1 purchsed back in 1997/98. The tape is stuck in the VCR and the eject won't work. The VCR switches off a few seconds after I hear a screeching noise, like car tires. I thought unplugging and plugging the power cord would fix the issue, but I still cannot eject the tape.
What's the easiest and safest way to remove the tape? I don't think I could repair the VCR, no experience with repairing electronics, but I would like to recover the tape, prior to taking it to a store, in case the repairman ends up damaging it in the process.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 09, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1759
Points
Turn over the VCR. Unscrew the base. You will see the 3 belts. Turn the rightmost belt clockwise or anticlockwise (don't remember) but you will see the tape hold mechanism moving down. Once it is all the way down, you can eject the tape out.
You may need to replace one or all 3 belts. This is being caused by belts being loose.
hope this helps.
Will Aiwa HV-MX1 Playback Extended Play (EP) Speed?
Probably not then, but you could try a tape recorded at EP.
2answers
Tape an catridge stuck
Unfortunately, the best chance you got of getting the tape out is to open up the video to release the tape.
When I push eject the vcr doesn't open the door and doesn't eject the tape
This is a common problem, either the tape drive motor, or the driver for same has failed. Sometimes it is a thing called the Mode switch too.
http://www.retrevo.com/support/Aiwa-HV-MX1-VCRs-manual/id/1077dj194/t/2/
So, it is nearly always my professional opinion that one should always get a "Quote" from the manufacturers recommended service center, Aiwa, in your case, please contact a local or head office and ask for a referral to an Authorised service center. I cannot stress how important that last point is. It is even worth the cost of shipping. You see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits.
AIWA VCR model HV-MX1problem
with the unit unplugged take the case off and look on both sides of where the front of the tape would set, you will see two towers, one is a light and the other a receiver,check to see they are plugged in and not obstructed.Also there is a switch that the tape pushes when its all the way in which might be stuck,click it a couple times with your finger.This might help, there are other more complicated things which could cause this problem but mechanical problems are more likely.
2answers
Tape stuck in VCR
more than likely one of the belts has broken
No Color
did u try cleaning the video head? heres how! unplugged the unit. open the cover. get a piece of clean white paper. put a little alcohol on it. place your finger on the paper and slowly touch the head but not too much force then gadually move the drum back and forth. donot move your finger up or down. just clean it horizontally by slowly moving the drum leaving your finger stationary. let it dry and test. if the problem persist see a doctor(technician), u have a problem with the color circuits. good luck!
Top Aiwa Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
john h
Are you an Aiwa Televison and Video Expert? Answer questions, earn points and help others
