If your machine is a FAV6800AW or FAV9800AW see if this post will help you clear the OD error code on your machine.
For the 'od' error, open the door and jiggle the locks. It's possible that soap has gotten there and is making them not knock whatever it is they need to knock to register that the door has opened. You might need something fairly long and thin such as jeweler's screw drivers. That just worked for us. Good luck to you.
OD light flashing and transmission fluid leaking?
http://repairhelpcenter.blogspot.in/2012/02/od-light-flashing-and-transmission.html
TRANSMISSION
FAILURES, OD WARNING LIGHT,
http://alltypesofpartsreplacing.blogspot.com/2012/12/transmission-replacing-and.html
These will help.
Thanks.
