What year?? I'll guess. press the < or > button until oil life appears. press and hold the select/reset button. 10 seconds. it will ask to confirm, press the button again. done. Dont reset unless you really have done the required maint. its really vital to keep your car running as good as it should.
SOURCE: how do you reset the maintenance required light?
Unhook your battery for 15min. This should turn the light off and reset it for you. Chris J.C. Towing
Sit inside the driver's seat of the Honda Accord and close the driver's side door. Any interior lights on can prevent the maintenance required light from resetting properly on some year models.
Insert the key in the ignition.
Depress the odometer/trip button located beneath the odometer on the instrument panel. Hold the button down.
Turn the ignition key two clicks forward to the accessory power position. This is also known as the key-on/engine-off position.
Continue to hold down the odometer/trip button for up to 15 seconds until the maintenance required light goes out. On some Accord models, the maintenance required light may blink once before going out.
Release the odometer/trip button and then turn the ignition key to the off position.
Start the Honda Accord to ensure the maintenance required light is no longer illuminated on the instrument panel. If it still is, the reset procedure did not take and you'll need to repeat the procedure.
