Master
- Posted on Sep 23, 2009
Re: How do I replace the door gasket on a Westinghouse...
The step by step procedure to replace the head gasket are:
- Open door and pull on inside of gasket to expose screws or 1/4 nuts.
- Loosen[do NOT remove] all screws and pull old gasket out.
- Place new gasket in sink of hot water to soften it and put back around door.
- Snug up a couple of screws on each side and test seal by shutting door.
- You may need to adjust inner panel until just right..then tighten all screws
There are no screws in this particular model, looks like the back of the gasket is secured in a groove or recess, as the front of the gasket is secured around a rim and clamped with a stainless steel ring.
