SNK Magnavox 42MF231D 42 in. Plasma TV Logo
Posted on Sep 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Magnavox 42" I purchased a Magnavox 42" Plasma.(model# 42MF231D) When I view anything on the TV, black and dark regions appear fuzzy with poor shading and WORST of all show a cloud of red pixels around the circumferance of the dark region. Any bright and lightly colored scenes look fantastic, but dark parts are nearly unwatchable due to it. Can this be repaired? Should I return the TV?=, black and dark regions appear with a cloud of red pixels around the circumferance of the dark regions. bright and white scenes look ok, but dark parts are surrounded by red pixels
Anonymous
Level 3:
President:
  • SNK Master 1,779 Answers
  • Posted on Sep 23, 2009
Anonymous
SNK Master
Level 3:
President:
Answers
1779
Questions
Helped
578615
Points
5452
You are correct=====Return it ! It's new, you should not have to have it repaired this soon.
1helpful
I HAVE 42 INCH MAGNAVOX PLASMA TV AND THE SOUND WORKS BUT THE TV DOES NOT SHOW A PICTURE AT ALL IT IS JUST ALL BLACK,COULD IT BE THE PICTURE TUBE THAT WENT OUT.
yes...the video card could have gone out but most likely you have a connection that is loose or bad. I would check those first. If you have done so then I would try another video port and verify that it is the screen that is out and not just the port you are in.
1helpful
My Magnavox 42MF231D 42" T.V
You may have a weak power supply. This would indicate one or two capacitors that are weak or bad. This model may be about 4 years now and this is a good indicator as these capacitors need replacing. The other problem may be the infared board in the TV that receives the signal from the remote may be a problem as well. I would certainly investigate my first thought. The latter is kind of rare. Thanks for asking and show a few hands of support.
Magnavox plasma tv model 42mf230a/37 sound but ni
Replace lower scan converter PCB, which plugged into Y-Sustainer Board, located to the left of the display if you poke back cover open. There are 2 of them, but in some models might be the one, long PCB.don't wait to fix it! otherwise, you will knock out Y-
Sustainer and upper scan converter. That will cause you to spend few hundreds to fix it.
Good luck,
Alex's TV Service,
Philadelphia,
Pa, 215-806-5980.
Magnavox 42MF231D/37 screen went white then black
Alot of times i have noticed that when i have worked on these, it has been the Backlight Inverter. 32 inch televisions had same problem as the 42 inch
3helpful
Magnavox 42MF231D/17, screen just turned black,
power supply or inverter board failing if the power board is the problem it will have blown caps
little cans with puffy tops because the caps have vented if you don't see that then your inverter has died that model id out of production so try shop jimmy. com
4helpful
There is no picture but have audio
Your mainboard is damaged and need to be replaced. in order to get a new one you will need a product code and model number, both located in the back of th TV next to serial number.
4answers
Black/Dark Colors Fuzzy w/Red Pixel Outline
Sorry, I haven't been on here for a while.
I haven't found the cause. I find that leaving it switched on overnight cures it.
Top SNK Televison & Video Experts
matt martin
matt martin
Are you a SNK Televison and Video Expert? Answer questions, earn points and help others
