Question about Kenmore Washing Machines
Kenmore he2t error code 21
Kenmore he2t front load washer error code F21
  • 1 more comment
  • Anonymous Mar 18, 2014
    kenmore he2t water temperature sensor
  • Anonymous Mar 19, 2014
    I want to go into diagnostic mode
  • Anonymous Mar 29, 2014
    keeps locking up and not running
  • 725 Answers
F21 is a long drain...it is taking too long to drain..you have a something slowing down the drain.. you can remove the bottom panel and clean out coin trap... if there is nothing then you may have another problem... but this is the most common problem..
Posted on Sep 23, 2009
  • 1 more comment
  • Cooldada Dec 24, 2010
    Lastnight our washing maching stopped worked and we mangaged to get the error code. I Googled the error and was directed to this Fixya solution. I didn't know what a coin trap was but I pulled off the bottom panel anyway figuring I'd be able to spot it. Voila, it was pretty obvious that the coin train was the approximately 2" wide hand-screw thing in front. In unscrewed it, and there it was, a massive clog of crud. I cleaned it out, put the screw back in, and restarted the washer and it worked!!!!
    I love the Internet. There was a time when I would have had to pay a repairman $200 because the information I needed to repair was only available in a specialized hard-copy manual.
    Shawn
  • rgpalafox198
    rgpalafox198 Nov 20, 2012
    how did you remove the front panel?
  • bgsystech
    bgsystech Feb 15, 2013
    three screws along the bottom of the lower front panel. and you might want a pair of pliers and something to catch a bunch of water as the "thumb" screw is a bit tight at first and the drain system is very full of water. be careful or you'll have water every where.
6ya staff
SOURCE:
Error code F-21
F21 relates to a motor or control board fault.
Sep 27, 2016 | Kenmore Elite 45986 Front Load Washer
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
I have a Kenmore HE2t i keep getting error f21 i cleaned the trap and it still does it
You may have to unplug it for about 15 minutes and try again. I had a similar problem and this helped.
Mar 19, 2014 | Kenmore HE2t 3.7 cu. ft. Front Load Washer
I have a kenmore HE-21 front load washer. I am getting an error code F 21?
It usually indicates a clogged drain filter or pump. Here is a link that should help F21 Fault Code Repair
Dec 28, 2010 | Kenmore HE2 Plus Front Load Washer
F-21 error on my Kenmore HE2t
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jun 15, 2010 | Kenmore 44102 Front Load Washer
F-21 on my window
F21  mean LONG DRAIN if the dreain time ixceeds 8 minutes the water valve turn off. *After 4 minuts the "Sd" error will be do;[;aied tjem 4 minuts later the        F/21 error code woll be displayed. * Press STOP two times to clear the display.
if this wont work the following mus be done by a technician.
Was this helpful?
May 09, 2009 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
2,189 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
