Very noisey sounds during spin cycleVery noisey sounds during spin cycle
AnonymousMar 18, 2014
When on the spin part of the cycle, washing machine giving a very loud banging noiseWhen on the spin part of the cycle, washing machine giving a very loud banging noise
AnonymousMar 20, 2014
Loud banging noise in spin mode. No leaking observed.Loud banging noise in spin mode. No leaking observed.
AnonymousMar 23, 2014
loud noise in spinloud noise in spin
extremely loud in spin cycleextremely loud in spin cycle
AnonymousMar 25, 2014
DURING THE SPIN CYCLE IT A LOUD NOISE AND SHOWS UNLEVEL.DURING THE SPIN CYCLE IT A LOUD NOISE AND SHOWS UNLEVEL.
AnonymousMar 29, 2014
clunking noise during spin cycle and will not spinclunking noise during spin cycle and will not spin
You can't post conmments that contain an email address.
If you balanced the machine, the only other problem could be the load itself. Either the load is too great or if washing a single item its falling to one side, tilting the drum and when spinning it will thump. Try even lodes.
Hello,washing machine is mounted on two supports, if it is damaged first which is where the engine so both need to be replaced because they wear out. If you're just a little handy so you know it himself .Ak you order parts so precisely that type because they are different .
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Check and see if the inner drum is loose and floppy.if it is, it's likely the bearings have collapsed, and require replacement...If the drum feels stiff and tight, it could be that something is jammed between the inner and outer drums. Both situations could be costly...Get quotes....Good luck...Nomess
Grab the agitator at the base and attempt to rotate it clockwise and counter clock wise. It should remain firmly in place. If there is movement the agitator spline is worn.
It does not come with the fabric dispenser. It has to be ordered seperately. You should be able to transfer you old one to the new one if you do have to replace the agitator.
Besides the agitator the drive bell can also be the source of the noise. It is located under the agitator.
The bearings have collapesd due to the seal going faulty. If bearings can be accessed to from the outside, it is possible you could do the repair. If big bearing and seal is accessed from the inside, suggest tech. do it as it gets dirty and a lot more complex.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
I had the same rattling during spin cycle of my Maytag 4000 series front loading washer. Noticed you could gently pull back on the rubber gasket between the tub and where the door seals. There was a quarter resting against the fixed ring the tub spins in. Problem solved. And I have further realized that long hair can build up in this same spot. But if you didn't know to pull back on the gasket you wouldn't see it. Good luck!
loud noise in spin
