Dryers Logo
Anonymous Posted on Sep 24, 2009
Fisher ED56 dryer wont turn off!
Hi. I have a Fisher ED56 model dryer and it will not turn off! Even when the door is open it continues tumbling away. Pressing the power button stops it for a second and then it starts. Opening the door does the same. Very strange! Any ideas? Thanks guys
Anonymous
Level 3:
President:
  • Master 267 Answers
  • Posted on Sep 24, 2009
Anonymous
Master
Level 3:
President:
Answers
267
Questions
0
Helped
129337
Points
1376
HI, this will occur if the timer control module or control board has failed. replacing the timer or control will fix this issue.
thank you,
vijay (vote for me)
Testimonial: "v quick reply. gave me something to work with. thanks"
1helpful
What age is our Fisher & Paykel dryer. ED56 Serial number 134182
https://www.productreview.com.au/p/fisher-paykel-ed56.html
Probably as old as March 1999 according to a review online.
May want to contact manufacturer if necessary.
Fisher Paykel 4 5kg ED56
1helpful
My fisher paykel ed56 wont go lights and buttons work wondering is there a reset button somewhere please
it may not be in that area your problem lies,a common problem is the capacitor. with the door open and the door switch activated by using a small screw driver,push start and try to rotated the bowl help it get rotating if it goes around with a bit of help to get it going then its the capacitor, easy to replace
1helpful
Fisher paykel dryer ed56
Could be the door switch or temp sensor. To check the door switch put pressure against the door and see if it stops. Check the slot the door hits to see if there is anything loose in there.
Jul 20, 2013 • Dryers
F&P ED56 has 2 problems
Yes, (2) certainly sounds like the start/run capacitor has failed. You will see it has a split or bulging case, or a displaced end cap. Replace it with one of the same voltage rating and capacitance.
I can't advise you on (1)
Tubmble dryer wont turn
Sounds like you have a bad idler and/or belt.
2helpful
2answers
My F&P ED56 dryer just hums when it is turned on. The lights come on and it hums, but it doesn't turn or blow air. We have checked the belt (that is OK), the drum can spin by hand, there is no lint...
sounds like it maybe the motor, here are other reasons the drum won't turn and how to open the dryer. Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
9helpful
Fisher & Paykel Dryer model ED56 constant beep
Diagnostic Mode
Entering the Diagnostic Mode
(a) Turn the power supply to the dryer on.
(b) Press and hold the Auto Dry down button, then press the Power
button.
The dryer is now in level 0 of the diagnostic mode. After initial entry into the
diagnostic mode, the Start/Pause button operates the dryer as normal. Press
the Auto Dry up or down buttons to scroll through the fault levels.
There are several levels of diagnostics, most of which are used in
development and production. These levels may bring on various LEDs, but
the level of use for the service technician is that of the last fault.
Last Fault
To enter the last fault diagnostics, enter the diagnostic mode as described
above, then press the Auto Dry up button three times. The last fault will be
displayed on the drying progress LEDs.
The manual is here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 08, 2009 • Dryers
21helpful
2answers
My fisher and paykel dryer ( mod# ED56 ) wont start, power is on
I had this same problem with my Dryer. It is making the few quick beeps because it thinks the door is still open. Near the bottom of the opening to the dryer there is a sensor switch that gets pushed in when you shut the door. Try holding the switch in with a knife or something and then start the dryer with the door open to check if that is the problem.
After i did this, i closed the door and my dryer started as normal.
9helpful
2answers
Fisher & Paykel Electric dryer wont tumble
I had the same problem,fixed it today with a replacement capacitor,cost $10 2nd hand (only cos I couldnt find a new one today and wanted it fixed now!)Unplug appliance, took off the back panel,underneath the motor on bottom left is the capacitor,remove the 2 wires, pull the capacitor out its bracket,replace,refit the 2 wires,replace back panel and Badabing Badabang!! My machine is working to full capacity again.
Pays to check out these forums doesnt it!!!
Top Fisher and Paykel Dryers Experts
Virgil Watts
john h
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
