Candy CN146 Front Load Washer Logo
Posted on Dec 16, 2007
Stop light flashing
I have a candy activa cm1 146. no matter what i do the stop light is consatntly flashing. Ive emptied the machine, turned it off at the mains, checked the waste pipe and currently trying to empty the filter, any help??
  • Anonymous Dec 18, 2007
    the stop light will not stop flashing, and it will not start any programe.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 28, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1263
Points
I have a candy activa cm1 146. no matter what i do the stop light is always flashing. Ive emptied the machine, turned it off at the mains, checked the waste pipe and currently trying to empty the filter, whilst the light is flashing it will not work on any programs???
I have a candy bianca washing machine and all lights just flashing with numbers onit and does its own cycle for a minute then stops then lights flash again any help guys
Hi all I have a candy bianaca washer dryer. When I switch it on it says welcome amd then shows long numbers across the screen. Wont let me select a wash or anything. Does its own cycle when turned on then lights continuously flash and doesn't do anything. Please help
I have a Candy CM126 washer. It will not go into the spin cycle. I have cleaned the filter and checked if the pump is ok. They are fine. However when the machine stops the Activa rinse and 90' lights flash...
It could be the NTC ? two small wires between the heat main wiring. Or Possible the heater is leaking to earth. You would need a meter to test , NTC should be about 18kohm
My candy go w475 washing machines stop working, the stop buton flashing all the time, colse the door but still flashing any help plz
clean the filter empty the machine at the drain filter !!!
check for rubbish in the pump viens {power OFF}
kirby grips clothes wires coins etc
perhaps you dont have the manual how to keep it clean
http://www.manualsdir.com/manuals/242947/candy-go-w475-s.html
2answers
Washing machine does not work on any program though stop light and spin speed light are flashing t
The stop light and the spin light flashing are acting as an error code. Have you tried to google what this means? here is a link to candy error codes for that machine...
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3319-candy-grando-washing-machine-series-fault-codes.html
hope that helps
2helpful
I have a candy go c58f and it is stopping after approx 10 secs of starting it's cycle and all the lights are flashing - I have checked the filters and emptied the water
This is a problem of the dryer being too cold. What you need to do is turn it off when all the lights flash (using the dial) then turn it back on again and start the cycle again. Repeat until it keeps going.
This is a real PITA. I spoke to their customer services about it and told me what to do. It seems the sensors in it are not happy in cold weather!
Mine takes 6 to 10 go's in very cold weather. I find it's best to get it warmed up when empty as the hot air gets to the sensors more quickly.
Sticks half way thro programme
found the problem,unplug machine pull out remove back cover screws look in side machine,there is a black pipe on right hand side bottom of machine,that is the drain pipe to the pump,remove jublie clips and check for blockages,mine was blocked refit cover and put machine on normal cycle to clean,
machine works fine now,
3answers
Candy Activa Smart 1300 AA
Click on your model number above, (below FIXYA) on this site, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Top Candy Washing Machines Experts
Kolbrun...
Oliver Street
ADMIN Andrew
ADMIN Andrew
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
