Question about Brother MFC 7840W Printer
MFC-7840w keeps saying "toner life end"
I recently ran out of toner in my cartridge and used a co-workers to print. After I used up the co-workers toner, I put a new one into the machine, but machine keeps saying "Toner life end." I can't get it to print! I've tried putting the cartridge into my co-workers, and it works in her machine. I can't get my machine to work again! What gives?
  • app_3rp12972
    app_3rp12972 Jan 28, 2012
    I have a brother mfc 7840w
    I first used the electrical tape trick and that worked for a while. Then got the toner low message again. I then tried the *00 trick, which works as follows:
    1. lift lid and open front cover
    2. press clear/back. "Replace Drum?" will appear on the screen.
    3. Press "*00" it will then read accepted and the toner low error (Toner Life End) should go away.
    4. close it all up and your done.
    New Friend:
After I figured this out, it was quite easy to resolve. Remove the toner cartridge from the drum cartridge. Remove the black plastic cover on the left side of the toner cartridge (3 Phillips screws). There is a "flag", which is a small plastic tab on the outer side set to the right at about 2 o'clock. Turn the gears until you fully reset the tab going counterclockwise to the 10 o'clock position (fully to the left). Reinstall the small black cover and the three phillips screws. And the idea to install black electrical tape over the small clear plastic windows on both sides is also a good idea to prevent the early and false message that the cartridge is empty. Make sure you do not allow that tape to get into the gears.
Posted on Sep 19, 2010
  • 2 more comments
  • Thank you so much. I tried 1st step did not work, until taped 2 plastics.:)
  • I had the problem for a week, almost throw the printer away. Thanks for the solution...:)
  • Frank Lu
    Frank Lu Jan 23, 2015
    The black electrical tape works! Thank you.
  • Anonymous Jan 02, 2018
    This worked for me, and I'll just add (1) location of the "flag", for me this was a very small point or arrow that was actually on the outer circumference of the outermost (right side--looking at end of toner cartridge)gear; and (2) I was unable to turn the gears to rotate the "flag" counterclockwise to the 10 o'clock position, but I was able to get it there by simply removing that one gear--pulling it off--then turning that one gear counterclockwise, and reinstalling it--carefully, have to re-mesh the teeth with adjoining gear.
    New Friend:
Open front cover ,press clear/back button, should see replace drum,ignore that , press*00 you will see accepted
Posted on Aug 14, 2015
6ya staff
SOURCE:
Drum Life Ends soon - Brother
The problem with this is the design. Each toner cartridge has a microchip on it, that counts the pages you print. The company has determined that you get x amounts of prints. Then you have to replace it, empty or not. This printers do not work the same way as an expensive professional business copier. In an pro style there is a spent toner cartridge that collects all of the wasted toner that is on the drum. On a small business/home style this spent toner goes back into the cartridge. There is no level indicator, even on the inkjet printer. They too, have a chip that says you have x amount of prints/cleaning cycles they can go through. Look up inkjet refill kits or inkjet cartridge programmer.
Mar 31, 2014 | Brother Mfc-7340 All-in-one Laser Printer...
Printer gives warning that toner life is gone. I replace the toner twice . Each time it prints one page and then gives error message. Page that did print out has dark horizonal lines.
Check the toner cartridge, side gears, you can see a reset lever (that lever is very important) show in the next picture.(cartridge new)
Jun 28, 2011 | Brother MFC 7840W Printer
HELP I put in a new cartridge and still get "Toner Life End Replace Toner Cartridge" HELP
Try to unplug the printer wait a min or so and replug it back in and see if this helps.
This will reset the printer
Apr 13, 2011 | Brother MFC 7840W Printer
I replaced the drum and toner recently, yet half of my pages are faded when they print. It seems to be on the left side of the pages that are faded. Any suggestions
The toner section may not be seated properly in the drum unit. Try removing the toner section and putting it back in the drum section being very careful to keep the cartridge in alignment with the drum.
Sep 28, 2010 | Brother MFC 7840W Printer
I replaced the toner for MFC 7840W and I am still gettin the toner life end message, I can not print. Please help
As noted from a previous poster, this one works!
3. Press "*00" it will then read accepted and the toner low error (End of Toner Life) should go away.
Thanks for all your help guys.
Jan 18, 2010 | Brother MFC 7840W Printer
It says toner life end and it prints just fine
The toner life end message means the toner is getting low. It will continue to print without any problem. Eventually you will see the print starting to get light in spots. If it is a new cartridge, the toner level sensors are probably dirty.
Oct 08, 2009 | Brother MFC 7420 All-In-One Laser Printer
We replaced the toner and it is still saying "toner life end replace toner cartridge." and we can't get it to print or fax or copy
Jun 23, 2009 | Brother MFC 7840W Printer
Want copier to use up more toner in machine
If you know where the "Toner Eye" is in the copier, cover it with black tape. Usually though, the copier counts the number of pages printed and then at a predetermined number thinks toner is low and stops printing. If the toner cartridge is chipped (has a electronic chip) it keeps the count in there. These type of cartridges are refillable, but still have the "Empty" count. The counter must be reset. These resetters are hard or impossible to get.
Replacing Toner
How to tell on brother mfc-8440 or mfc-9440cn , the total copies printed so far
Sep 07, 2008 | Brother MFC-9440CN Laser Printer
Brother MFC 7840W Printer Logo
11,006 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
