Good day,
This tip will explain how to remove the write protect from your SD Card.
This is a easy fix and won't take a minute.
First remove your SD Card from your device. You will see on the side of the SD Card that there is a
small switch. If your SD Card complains about being write protected simply put the switch in the
opposite position. Some of the SD Cards even have the word
LOCK on near the switch indicating the direction the switch must be to
LOCK the card.
Once the switch is changed you can put the SD Card back into your device and the problem of write protection would be solved.
Please feel free to let me know if this tip was able to help you!
Regards
