SOURCE: Much louder noise from the unit than usual
The Sanibest has a pressure sensitive switch that activates when the water pressure inside the unit gets to a particular level. It is basically a microswitch sealed in a watertight container.
If the Sanibest has got gunked up inside it is possible that the unit is not kicking in soon enough and the water is backing up into your shower.
Another possible issue is that something has got into the Sanibest that should not be there that is impeding the flow out of the unit.
For both cases I would suggest that you empty the cistern and WC bowl after running clean water through th unit for a few miunutes (makes the job a bit less horrible!).
You could also try and use SaniFlo cleaning product and hope that it clears the potential blockage http://www.sanifloproducts.co.uk/products/Saniflo-Products-Saniflo-Descaler.html
** ENSURE THAT THE VERY FIRST THING YOU DO IS TURN OFF POWER TO UNIT **
1. Turn off the electricity to the unit (should be on a fused spur)
2.
Disconnect
the pipes (inlet and discharge) - you may get a bit of
surplus water coming out so have some sponges and a bucket ready.
3.
Disconnect the wiring and take the unit out
4. I clean my Saniflo's
outside with warm bleach water ..
- Wear rubber gloves to keep
germs out of any cuts you may have / get on your hands
- Put the
elextrical cable in a taped up plastic food bag or similar to keep dry
- undo the 'star screws'
- Flip up the plastic retaining
tabs with a flat blade screwdriver and gently ease the lid up.
- I put bleach and warm water in, leave it for a while (30 mins) and
then swish it around and empty out into an outside drain etc
- If
you want to use an old toothbrush to get into the areas by the float
switch and under the motor it does help. I also used a hosepipe in the
past which did the trick.
- Also pay attention to the inlet port
and the actual pipes under your sink for gunk
put
it back together, aligning the seal and plastic clips should just pop
on (may need a firm push). Do up star screws and you are ready to
reconnect the pipes and electrics.
I use some tissue paper to
check for any leaks around the pipes just to be sure!
Another point to note is that you can insert a simple non-return valve into the pipe near the shower to stop the water coming back up; however this is not addressing the root cause.
Hope this helps - if so, please leave feedback. If not let me know and I'll try and help some more!
SOURCE: I have a saniplus in a bathroom with a sink &
If the pump is humming and backing up then there is a blockage on the drain pipe, blades or the impeller. Also the capacitor may have gone bad and it will need to be replaced. The capacitor drives the blade and impeller, if it goes bad then it would just hum and not pump out the waste.
SOURCE: Thinking about installing basement Saniflo toilet
Zoeller makes the best unit out there do you research first
SOURCE: My up flush toilet makes a humming sound every 5
The pump has either gone bad or it is siezed up...you can try to unplug the pum and let it sit for a few hours then plug it back in... sometimes if you jog it on and off a few times you can get tiit to break loose and work again...if not you will have to take it out and replace the pump.
heatman101
