Your unit is not a self defrosting freezer and consequently has no defrost timer. There are only four components required for cooling in your unit. The temperature control, behind the knob in the cabinet. The compressor at the back bottom. The start relay and overload in a box attached to the compressor. The run capacitor attached to the start relay. A failure of any of those will cause the compressor not to run.
Check the wall outlet to be sure you have power.
If the compressor IS running but not cooling, the compressor itself may be defective or the gas charge may have leaked out. Compressor and refrigeration problems are likely beyond your capabilities in terms of knowledge and equipment.
The temperature control may be tested by all connecting the wires of the control to ONE terminal after unplugging the freezer and marking down teh original locations of the wires. If the compressor runs and cools after this by-pass then change the control and return the wiring to the original locations.
If the above does not make the compressor run the next possibility is changing both the relay/overload assembly AND the run capacitor. If these fail to correct the problem you need a new compressor but you will likely NOT be able to return the parts replaced.
Good Luck
