Hi My 4 year old Frigidaire front load washer will not wash or spin. Only fills up and drains. Runs through cycle, but just fills with water,sits,drains. Fills for rinse cycle, sits,drains. Buzzer sounds as if done. Door unlocks.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
heatman101
Problems
related..
Washing
Machine
Front
Load Washing
heatman101
heatman101
fills with the water but does not go into wash cycle and eventually just drains and shuts off
...We have a Mabe washer/dryer combo...two problems, but the main one now is...sometimes the water just runs and runs...won't fill the washer, but fills part way and then drains little by little, so will just run forever. Tried resetting, unplugging, running spin cycle then trying again....nothing seems to work well. Something with sensors??
puts too much water in does not wash but goes to drain and OL comes on
My frigidaire washing machine does nothing when the control knob is turned. Washer stopped spinning in middle of cycle so i turned the control knob to the position where it usually drains the water. The water drained out and then afterwards the control knob does nothing else. Washer doesnt fill now or spin.
its the 5 cycle washer
water keeps running into washer after spin cycle
water runs but just drains out. will not fill.
