Amana 16.8 cu. ft. / 476 liter Upright Freezer Deepfreeze AFU1705B Logo
Posted on Sep 27, 2009
I can't use my hard disk after i installed deep freeze
I cant use my hard disk which is installed deep freeze 6.0, but then someone change password. even i reinstall windows, format this hard dis, even try using low level format, it seem doesn't work. i don't know what to do. does anyone can help me fix this problem? what software i should use, because my hard disk can't be accessed again? thanks in advance. biebe.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 31, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
240
Points
WITH CTRL+ALT+SHIFT+F6 IN YOUR MONITOR WILL APPEAR A WINDOW.THERE YOU WILL CHOOSE BOOT THAWED AND THEN YOU WILL HAVE AN ACCESS IN YOUR HARD DISK.
Frigidaire upright freezer ice forming in bottom and leaking not freezing ice cream
This does not sound good because the breakers tripping may indicate a compressor windings short. Have someone do the test below,
Unplug the refrigerator and remove the back panel that covers the compressor. There should be 3 wires going inside the cover of the compressor. Mark all 3 and mark their location so if compressor is OK you can put them back in same order. The plastic cover may snap on and you may need to squeeze the sides to unlock the cover and sometimes there is a metal clip holding the cover in place. Remove the cover. May look hard but it's simple. There will be three connections under the cover and 2 will go through the start relay. Unplug them leaving the three prongs exposed. They may be marked R =Run, S=Start and C=Common. Set your meter on continuity and then begin by testing 2 at a time until you have checked S to R and R to C an C to S and S to R again. You should get a reading all the way around. If no reading between any of the pairs as you go around you should get no reading between any two the compressor has an open winding and is defective. Then if it passes that test then touch one probe to R and the other to the copper pipes or clean metal on outside of compressor, then S to metal outside and C to metal outside. If you get a reading this way even just a little. The compressor is a burnout. Then let me know what you find. Thanks, Sea Breeze
2answers
How to regas chest freezer
Hi. The deep freezer is working but not freezing
Mar 28, 2012 • Freezers
Which no should my LEC be set at 1 or 6 for deep freeze?
the higher the number - usually the harder the motor works - so for very cold - go 6
May 27, 2011 • Freezers
1helpful
My deep freeze locks on its own. We dont have a
nothing to do with temp changes. only to do with a broken lock mechanism.
2helpful
How to close the deep freeze
click on it with shift and type your password and restart the computer
Am I supposed to turn off the quick freeze once the deep freezer is cold?
http://www.mcappliance.com/document/MCCF5WBX.pdf
i read the entire manual and even type in the words "quick freeze" in pdf. find space and it is not in there.
heres the link read it for yourself
it only mentions green light and red light.
The “POWER” light (Green) indicates that the freezer is properly connected to the electrical power.
The “RUN” light (Red) will not illuminate when the unit is operating below freezing.
The “RUN” light will illuminate when the temperature inside the unit increases above freezing. Please
be advised that the “RUN” light may come on for a period of time when the lid is opened, when new
items are stored inside the unit or when the lid is forced open by irregular contents.
Do not call for service unless the “RUN” light has remained on for 6 hours or more. If this light stays
on continuously for a period of 6 hours, please contact our Customer Service Dept. to consult with a
representative at 888 775-0202 or visit our website to request warranty service at www.magicchefewave.
com.
1helpful
Deep Freeze not freezing
this could be from a faulty temp controller however my best! bet is it's low on froen due to a high pressure leak
1helpful
Why the deep freezer ice up inside top front
It freezes up because there's warm air going through the door or the gaskets are letting the outside air getting in.
Apr 07, 2009 • Freezers
3helpful
5answers
How to uninstall deep freeze from your pc?
how yto uninstall deep freeze, password forgotten
My deep freeze outside will not stay cold.
a freezer is just a heat pump . from inside the freezer to the garage . the first law of thermodynamics says heat travels from a hotter to a colder surface . it could just be the cold how much are we talking?
Top Amana Freezers Experts
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you an Amana Freezer Expert? Answer questions, earn points and help others
