It's a common problem with the software in the TV. Updating the latest software for the TV should fix the problem. Here's a link for the Philips web site to get the software upgrade.
I had an LG 37" LCD that did this to me. Turned out to be bad solder joints on the side button board. Just reflowed and it starting working fine.
But now that I think about, I had another set do the same thing, only it wasn't the button board. I had to upgrade the TV's firmware via the USB service port. Just needed a USB flash drive and downloaded the firmware from the mfg's website. There were easy to follow instructions there too!
It's a software problem with the TV. Go to the PHILIPS web site for downloading the latest software upgrade for your TV to fix the problem.
Lots of Philips TV are having the same problem. Philips support should provide the software for free.
Philips.com should have a software upgrade for your TV to fix the problem.
This is a common problem with Philips TVs and they have made upgrade software to address the problem.
Go to the Philips web site and all the procedures for download to your TV will be there. The only thing you will need to this is a USB memory stick. Download should be FREE.
Go to the philips consumer website, input your model. You are going to look for current software updates. Download the the software to a memory stick. Once downloaded, insert memory stick into USB port on TV. It will upgrade automatically and your problem will be solved. Let me know if I can be of further assistance
When I turn on my TV
it goes straight to the menu screen. You can still hear sound but no
picture. When I try to exit you see the picture for about a second then
it automatically flashes back to the menu screen. Even if I try to use
the functions in the menu screen it flashes right back to the main menu
screen. Very frustrated...need help!
Is this a plasma TV ? If so remove the back cover of tv and unplug the cable that plugs into the IR board from the SSB that receives the signal from the remote. If it stops you panel is causing interference with the signal. If it doesn't your problem is in you SSB. you might see if there is a software upgrade offered by the producer of that TV.
Sounds like the button cluster has an issue...see if the menu button is stuck and if not, repair may be needed to disassemble the TV and have a look at the control section.
