Somehow the configuration of the scanner has been changed.
You need to use the configuration codebook and the "ADF" rules to correct the post-amble character. For Excel I know DOWN arrow works.
One word of caution. The manual is quite confusing regarding how to get the right post amble in there. You have to look up the 4 digit code in a table (in the manual) and then scan that code in one digit at a time.
If memory serves me correctly the little 3 page paper owners manual that comes along with the scanner has a default barcode on it. I'm thining the default puts the post-amble you need into the scanner ..but it will wipe out any other changes you have in there ... hopefully there are none.
Excel Workbook
.xlsx
The default Excel
file format. Cannot store VBA macro code or Microsoft Excel 4.0 macro sheets
(.xlm files in Excel 4.0).
Excel Macro-Enabled
Workbook
.xlsm
Uses the same basic
XML format as the Excel Workbook, but can store VBA macro code. Users saving
an Excel workbook that has VBA code or Excel 4.0 macro sheets (.xlm files in
Excel 4.0) are prompted to use this file format.
Excel Template
.xltx
The default file
format for an Excel template. Cannot store VBA macro code or Excel 4.0 macro
sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled
Template
.xltm
Can contain a
VBAProject part or Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Workbooks created from this template inherit the VBAProject part or Excel 4.0
macro sheets that exist in the template.
Excel Add-In
.xlam
A supplemental
program that runs additional code. Excel add-ins use the Open XML file format
to store data, and they support using VBA projects and Excel 4.0 macro
sheets.
