How do i get the screen on the printer back to english from spanish
Had problem before with Vista OS and had to go to Microsoft website to download patch.
Check the settings in your printer program ... control panel - printer - select yours and look among the tabs for the solution to your problem
MAYBE, you have a Spanish print driver ... In that case, go to the manufacturer web site and find the English version.
SOURCE: Oki C5150 printer menu is part english part spanish
How To:
Uninstall a Spanish or Portuguese driver and install
the English version when Windows XP installs the incorrect language,
where either a couple of the tabs are in the wrong language, or
everything is incorrect.
Action:
IMPORTANT NOTE: THE PRINTER MUST BE
TURNED OFF DURING THIS PROCEDURE OTHERWISE WINDOWS WILL AUTOMATICALLY
INSTALL THE SPANISH OR PORTUGUESE DRIVER AGAIN. DO NOT USE PLUG 'N PLAY FOR DRIVER INSTALLATION.
1. Delete the Driver Icon from the Printers and Faxes Window.
IMPORTANT STEP:
2. Reboot the PC
3. Click on File --> Print Server Properties
5. Click on the Drivers Tab.
6. Highlight the driver being deleted (C5200n shown as a reference below), and click on Remove.
IMPORTANT STEP:
7. Reboot the PC
8. Go back into the Server Properties Drivers Tab (as shown above), and click on the Add... button.
9. On the first screen click on Next.
10. On the Printer Driver Selection Screen, click on Have Disk.
11. Browse to the location of the English driver
that is to be installed and click on OK (Note, the C5200n printer is
being used as a reference and the driver being installed is from the
CD).
12. On the next screen the printer being installed should be highlighted, and click on Next.
13. The next window Will show the version of the
driver being installed, DO NOT click on any of the unchecked boxes and
just click on Next.
14. Click Finish on the last window.
15. Finally, turn on the printer. Windows XP will
automatically find the printer and install the English version of the
driver.
SOURCE: change language from spanish to english on my printer
Press and hold the Cancel button then press the Help button to change the Control Panel language.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: the language on my printer screen is spanish, I
follow this steps Go to Menu > Maintenance > Set Language & Country/Region > Press Start for English > hope this helps
